Author Topic: Smoke and noise  (Read 4547 times)
February 12, 2009, 03:00:39 pm
Jettage1
  • 202
    Past VWs: 80 Scirocco S, 90 GTI, 00 Passat GLX
Smoke and noise
« on: February 12, 2009, 03:00:39 pm »
I have two issues, (well, regarding my Jetta anyway...) they may or may not be related:
The facts:
1.  New IP - Giles modified, now with LDA (unlike stock ECO pump)
2.  New timing belt, water pump, rebuilt injectors, new heat shields, new glow plugs.
3.  Engine timed following Bentley and Vince's how-to.  If anything, it's slightly retarded now, prob. just under 94.
The issues:
1.  Intermittent noise - usually louder when cold, but intermittently loud when at operating temp.  (Sometimes very loud, sometimes not there at all.)  A staccato "TACK-TACK-TACK-TACK" sound.  Always louder at idle, just off idle, and when I'm lugging it up under load.  Gone at higher rpms - say 2,000 +.  This noise wasn't there before I did all of the above work.
My guesses:  a bad hydraulic cam follower / lifter?  I plan to pull the valve cover this weekend & check them.  Second choice:  stuck injector, except that (a) they're new, and (b) the screwdriver test didn't reveal one dramatically louder than the other.  The two at the end away from the belts were a bit louder though.  According to Giles, the IP has an aggressive advance curve, so maybe this is part of it, but I do have the timing fairly low...
2.  Smoke is inconsistent - that is, I can have some days where when the car is up to temp, no matter how hard I flog it, I just get a light haze out the back.  Other days (like today) there is much more light grey or even dark smoke, even under lighter throttle.  I have no idea what's going on - seems to me it shouldn't change like this...
All ideas, postulations, proffers and wild a$$ guesses welcome!
And thanks!
Steve
92 Jetta EcoDiesel
     pumped by Giles...powered by Frybrid...functional by dumb luck
Reply #1February 12, 2009, 03:33:09 pm
  • 1739
Smoke and noise
« Reply #1 on: February 12, 2009, 03:33:09 pm »
My first guess was a defective injector, but while you are checking the lifters, if you pull the cam, check your valve springs. While one bad one will always give the same symptom, 2 or more weakish ones will cause intermittent problems. And also check how the lifters are in the bore. the lifters may be good, but maybe you have one or more bores worn out. As the lifter turns, it gets oil, sometime not.
Reply #2February 12, 2009, 03:54:36 pm
Jettage1
  • 202
Smoke and noise
« Reply #2 on: February 12, 2009, 03:54:36 pm »
When you say the lifter bores might be worn out, do you mean they would be oversized and/or out-of-round?  How do I tell?  Is it that the lifter would be loose / rattly in the bore?
Steve
92 Jetta EcoDiesel
Reply #3February 12, 2009, 04:48:27 pm
  • 1739
Smoke and noise
« Reply #3 on: February 12, 2009, 04:48:27 pm »
The  worn ones i've seen were oval, but very hard to tell. they were on taxi's that had a very hard life,  running 24 /7 and not always with the best oil. If i remember ,it's obvious when they are worn. When they are good, the lifter should have some drag going in when they have oil on them. The springs will be  obviously  harder to tell without removing them.
Reply #4February 12, 2009, 08:02:44 pm
Smoke and noise
« Reply #4 on: February 12, 2009, 08:02:44 pm »
i don't really know too much about diesel timing and the effects on the engine.. But aren't ECO pumps supposed to be timed to a stock setting of 1.00mm, and performance setting of 1.00-1.05mm.
Would having the pump set at; "If anything, it's slightly retarded now, prob. just under 94." Cause an issue?
That should be way retarded for an eco pump. Try adjusting the timing maybe? before tearing in to the engine.. I dunno if that's the problem.. but it sure could be.
Reply #5February 13, 2009, 03:47:34 am
Smoke and noise
« Reply #5 on: February 13, 2009, 03:47:34 am »
If it didn't do this before the new parts I would start there. Also if it sat for a month or more without moving I would suspect sludge in the oil and would get it hot and change it, it won't hurt.
The intermittant smoke would seems most likely to be the injector not working correctly. Again if it sat for a while the fuel could be crap as well. Just some things to think on.
Reply #6February 13, 2009, 04:31:23 am
Jettage1
  • 202
Smoke and noise
« Reply #6 on: February 13, 2009, 04:31:23 am »
Cave - thanks for the extra info.  If I dig down below the cam, I'll check  those things as best I can.  Engine has 210K miles, so some of my issues may just be long term wear...
Hi Jeremy - yes it's retarded for an ECO (take that anyway you like... :D), but mine is a Giles performance build with an LDA (which the ECO didn't have).  When I found that it was noisy after the install, I backed off the timing to see what effect it might have, esp. since I wasn't dealing with a stock pump anymore...I had read that too much advance could cause excess noise.
And theman53 - thanks for your ideas.  I hadn't thought about the oil, but I am due for a change, so I'll add that to my checklist.  I like your thought about the injector causing the intermittent smoke.  If I can get the noise to really hammer at idle, maybe I'll try the injector crack test (open each line in turn) and see if the noise changes.  My last fill-up could have been as much as a month ago.  I run veggie (carefully!) so I don't burn my diesel tank very quickly.  I did recently add a glass in-ine filter (mainly for observation purposes) so I'll monitor that & see how the fuel is looking.
Thanks for all the input...  I'll mess around on Saturday and report back...  Keep it comin'!
Steve
92 Jetta EcoDiesel
Reply #7February 15, 2009, 02:04:44 pm
Jettage1
  • 202
Update
« Reply #7 on: February 15, 2009, 02:04:44 pm »
Update:  damn thing makes me crazy.  Did get the oil changed at least.  When I took it out & got it warmed up, for part of the drive it was smokier under load, and also noisier at idle.  "Good", says I, & headed home to do some testing.  But while headed home, the smoke was less and when I pulled in it was almost as quiet as a gasser.
Aaaaargh!!!  How am I supposed to fix it when it's waffling all over like this?
 :evil:
Steve
92 Jetta EcoDiesel
Reply #8February 15, 2009, 04:09:39 pm
Smoke and noise
« Reply #8 on: February 15, 2009, 04:09:39 pm »
sounds to me like the injectors might have been sticking?  or they just needed to be broken in a little?
keep driving it, and don't baby it.  it might just need an italian tune up  :lol:
Reply #9February 15, 2009, 04:18:30 pm
Jettage1
  • 202
Smoke and noise
« Reply #9 on: February 15, 2009, 04:18:30 pm »
Quote from: "jtanguay"
Maybe so, but it's been doing this for a couple of weeks...  The injectors were rebuilt by Giles & installed with the new IP...
Sometimes when a vehicle is frustrating, it is cathartic to just wring the snot out of it!  :lol:
Steve
92 Jetta EcoDiesel
Reply #10February 15, 2009, 05:39:22 pm
Smoke and noise
« Reply #10 on: February 15, 2009, 05:39:22 pm »
Don't baby it.  it might just need an Italian tune up  :lol:
Hey man, that works on alllll engines; big, small, gas, diesel, 2 stroke or 4 stroke.. Every engine benefits from a good rippin' IMO :lol:
Reply #11February 16, 2009, 12:38:22 am
88jetta350
Smoke and noise
« Reply #11 on: February 16, 2009, 12:38:22 am »
Quote from: "8v-of-fury"
I would have to agree with this statement. Most engines, especially Diesels, HATE being babied. I found this out the hard way with my Daytona, since the PO babied the hell out of it. I get it and proceed to drive it like any normal person w/ a Turbocharged Gasser.  :twisted:
*cough* anyway, now I'm wrapping up changing the Intermediate shaft, oil pump, and bearings....
Reply #12February 16, 2009, 03:59:26 am
  • 3468
    • McScrubbins Body Wash
Smoke and noise
« Reply #12 on: February 16, 2009, 03:59:26 am »
I agree too with givin'er some pedal. Before my rings seated it was loud as hell and sounded like death. I think (with the any engine) you need to get the rpm up (when hot) quite frequently to ensure the oil gets EVERYWHERE.
Reply #13February 16, 2009, 05:15:22 am
Smoke and noise
« Reply #13 on: February 16, 2009, 05:15:22 am »
All that is good and the more you throttle tune it as I call it, if something is completely screwed then you will know it sooner than later :lol:
Reply #14February 16, 2009, 08:17:31 pm
zyewdall
  • 393
Smoke and noise
« Reply #14 on: February 16, 2009, 08:17:31 pm »
Are you running it on veggie oil when it's doing this variability?  That could be part of the issue.  We had a '74 Mercedes that we were running on veggie oil, and it would get as quiet as a gasoline engine when it was idling on veggie... and typical mercedes clatter when on diesel.  The smoke also changed from black smoke on accelleration with diesel, to faint gray smoke all the time, but much less black on acceleration when on veggie oil. For testing purposes, maybe keep it on a tank of B20 for a while to see if that's the difference.
Z
'89 Subaru 4x4 touring wagon
1976 Ford Sasquatch pickup
