AAZ oil return fitting
Topic: AAZ oil return fitting (Read 1995 times)
February 10, 2009, 06:52:37 am
stewardc
February 10, 2009, 06:52:37 am »
I need the banjo bolt and fitting that go in the block for the AAZ turbo oil return. Anyone got one, or a source?
February 10, 2009, 07:15:11 am
February 10, 2009, 07:15:11 am »
If you had a drill press you could make one.
Wouldnt be easy but it's doable.
Hopefully someone will have one for ya though. I'll be burn can get ya one.
February 10, 2009, 07:57:17 am
GEE-BEE
Fittings
February 10, 2009, 07:57:17 am »
anplumbing.com
Iam sure they will mail you what you need
Enjoy the samples !
Gee-Bee
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
