Author Topic: Need a little help...leaky IP...tried ATF...now no start.  (Read 4450 times)
Reply #15February 08, 2009, 12:56:13 pm
dubbinchris
  • 36
« Reply #15 on: February 08, 2009, 12:56:13 pm »
Well if I only had a test light...haha. I only have a digital multimeter.
Anyway I'll keep all that stuff in mind. My biggest concern is the leaky IP.  It drips a fair amount of fuel.  I don't need to sweat it though b/c this car isn't currenly my DD.  I may also be pulling the driveline to drop into another car I'm looking at thats a gasser with a bad tranny.  Pulling the IP to reseal it while pulling the motor would make the most sense to me.  I like keeping back up cars so as the car sits right now, it's drivable in a pinch even with the leaky IP.  It's certainly not drivable if the IP is off the car.
I'm trying to decide if the IP reseal is something I want to try and tackle myself or if I want to have someone else do it.
1983 Quantum TD
1988 Fox Wagon
1991 Wolfsburg Golf
1986 NA Diesel Golf (sold)
1990 S-10 Blazer
Reply #16February 08, 2009, 01:05:31 pm
  • 1739
« Reply #16 on: February 08, 2009, 01:05:31 pm »
You can the meter instead of a light. Use the ohmmeter to check resistance. They should test out with no or low ohms.
The leak's gonna make a bit hard to start also, depending how bad it is and where.
Reply #17February 08, 2009, 01:09:12 pm
dubbinchris
  • 36
« Reply #17 on: February 08, 2009, 01:09:12 pm »
Quote from: "the caveman"
Ah yes...that makes sense about the resistance.
As far as starting goes, it has not had any trouble starting even with the leak in it.  It's just a decent size drip every 2-3 seconds.  Not enough to really effect the function of the pump, but enough to make a decent size puddle in a few minutes and stink up the car when driving.
1983 Quantum TD
1988 Fox Wagon
1991 Wolfsburg Golf
1990 S-10 Blazer
