Author Topic: Boost Pressure #'s  (Read 8712 times)
Reply #15February 05, 2009, 07:56:03 pm
CODE4LS1
  • 73
Boost Pressure #'s
« Reply #15 on: February 05, 2009, 07:56:03 pm »
I have done this conversion on my N/A diesel and so far so good.  No excessive blow-by and no oil consumption so far.  Still at stock boost settings 10-12psi until I find an intercooler.  I go up hills in 5th gear now!
Reply #16February 06, 2009, 03:57:54 am
camboscams
  • 324
Boost Pressure #'s
« Reply #16 on: February 06, 2009, 03:57:54 am »
CODE4LS1, did you notice a pretty good power gain after this gain? What were your milage numbers after this? do you have a MLS HG and head studs or are you running this much boost with a factory HG?
81' White 1.6l Rabbit 4dr Holseted
72' Ford F-250 390cid
2014 JSW 2.0L TDI Stg 2, CP3 HPFP
Reply #17February 06, 2009, 05:52:06 am
saurkraut
  • 904
Boost Pressure #'s
« Reply #17 on: February 06, 2009, 05:52:06 am »
You can get allot of power, with very little smoke and a low EGT.
When I was road testing my 1.5TD, it had NO PROBLEM accelerating in fifth gear.  I did a four car pass with it on a two lane road where the posted speed limit was 55.  It completed the pass no problem, with a terminal speed of 85MPH and it hadn't topped out yet.
Here is the formula:
Head studs
2.5" pipe, turbo to rear bumper
Pre turbo EGT measurement
TD pump
Disable the POS blow off valve.
Disconect plug the waste gate line.
Back out the governor screw the widthe of one jam nut
Readjust the pin on the throttle arm to make use of the additional travel
Fire for effect.
Studs are manditory.  The metal head gasket is optional.  I ran a butt load of boost (30 PSI)on my 1.6 for years with the stock head gasket and Raceware head studs, and never had a gasket failure.  I eventually broke the cylinder head; cracks across the entire span of the bore, all cylinders.  ( I'll clean it up and take some pictures, Its impressive)  The stock head gasket was still good.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #18February 06, 2009, 10:26:52 am
CODE4LS1
  • 73
Boost Pressure #'s
« Reply #18 on: February 06, 2009, 10:26:52 am »
Quote from: "camboscams"
Very noticeable power gain.  When I floor the accelerator it goes right up to 12psi and stays there.  Still using the factory fiber HG and factory head bolts.  No problems yet but I am buying the ARP studs and metal 1.9 HG so I can turn up the boost later.
My mileage is between 35-37 US MPG.  This is because my Caddy is my work vehicle so I carry all my carpet cleaning equipment in the back, as well as the shell.  My driving style also plays a part in it, as I like to go 75-80 MPH on all the freeways.  I still think 35-37 MPG is excellent considering all the weight I pull around in it.  My 2000 Chevy S-10 with the 4.3 V6 only got about 21 MPG at best with my driving style
Reply #19February 06, 2009, 10:33:37 am
53 willys
Boost Pressure #'s
« Reply #19 on: February 06, 2009, 10:33:37 am »
I always thought it was the compression strokes combustion pressure with the added boost that blew the head gaskets. But from Jt's statement it is the EGT's that do it.
Interesting....
nope your right...EGT's dont kill head gaskets...excessive drive pressure does....
excessive EGT's melt pistons and break down oil and engine parts...but have no effect on the HG...
EGT's do not kill headgaskets....
drive pressure is VERY important!!
Reply #20February 06, 2009, 12:11:53 pm
spencebm
  • 686
Boost Pressure #'s
« Reply #20 on: February 06, 2009, 12:11:53 pm »
how do you lower the drive pressure?
Ben Spencer
Reply #21February 06, 2009, 12:27:45 pm
Boost Pressure #'s
« Reply #21 on: February 06, 2009, 12:27:45 pm »
what exactly is the drive pressure?
Reply #22February 06, 2009, 01:07:44 pm
MJF
  • 581
Boost Pressure #'s
« Reply #22 on: February 06, 2009, 01:07:44 pm »
Exhaust Manifold Pressure. The bigger exhaust housing, the lower emp.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #23February 06, 2009, 01:50:05 pm
camboscams
  • 324
Boost Pressure #'s
« Reply #23 on: February 06, 2009, 01:50:05 pm »
As in, the exhaust turbine housing, or the manifold itself?
Thanks CODE4LS1, that is very useful info to me! Now I know what my comfey limits are :wink: Cant wait to get this bad boy on the road, need to finish the bodywork and paint first :wink:
Reply #24February 07, 2009, 08:54:38 am
hamradio
  • 282
Boost Pressure #'s
« Reply #24 on: February 07, 2009, 08:54:38 am »
Here's my once-1.6na-now-VNT15 rabbit.
http://www.youtube.com/watch?v=ckHUSaZrYsE
Kind of a poor video, but it shows how quickly the turbo spools.
I'm controlling vanes with a pneumatic actuator.  I quickly threw together a boost controller one day, and drove around on 15 PSI.  My boost controller could not react quickly enough, or something...On every shift, I could easily spike to 20-25 psi...it pegged my 15 psi gauge quickly.
Reply #25February 07, 2009, 09:12:56 am
Boost Pressure #'s
« Reply #25 on: February 07, 2009, 09:12:56 am »
cool video! wow vnt's spool like instantly eh? lol
Reply #26February 07, 2009, 09:21:34 am
Boost Pressure #'s
« Reply #26 on: February 07, 2009, 09:21:34 am »
Quote from: "8v-of-fury"
ya.. i like this video of Tintin's old VNT-20 TDI
Reply #27February 07, 2009, 09:34:16 am
camboscams
  • 324
Boost Pressure #'s
« Reply #27 on: February 07, 2009, 09:34:16 am »
Thanks for the video Hamradio! You running a straight pipe exhaust, that VNT spooling up and down is loud...Awsome! :D
Reply #28February 07, 2009, 07:01:01 pm
Rabbit TD
  • 840
Boost Pressure #'s
« Reply #28 on: February 07, 2009, 07:01:01 pm »
Well if i had a choice i'd perfer not to melt my new "King" pistons. so basicly what i gather from these statements is to keep enough boost to keep the smoke levels down. But not enough to blow the HG.(If only i knew what the magic number is? :lol: )
but there is a solution! VNT
BTW the IHI is ballbearing 30% faster spooling then thrust
bearing :twisted:
Did you get your pistons at Parts Place by chance?  I just got a rebuild kit for my T/D from them and that's what mine are.  The last kit I got from them had Mahle pistons with it and I just hope these KING ones are as good as the other ones are.  Actualy I'm more concerned about the rings.
Reply #29February 07, 2009, 08:38:57 pm
camboscams
  • 324
Boost Pressure #'s
« Reply #29 on: February 07, 2009, 08:38:57 pm »
Sure did, hefty price, after miking the pistons (which where all to same size) i bored and honed my block, they slipped right in, noooo problems :) .......Plus they already had the cut outs for the piston oilers, i don't have them but that would be nice to skip that step if that day ever came when i wanted to install them. Time will tell how they hold up. I'll let you know how they held up about 400,000miles from March :lol:
