Author Topic: EGT Guage  (Read 8609 times)
Reply #15February 13, 2009, 12:34:18 pm
EGT Guage
« Reply #15 on: February 13, 2009, 12:34:18 pm »
Quote from: "Heavy D"
Quote from: "Smokey Eddy"
WELLLLLLLLLLLLLL
I only have a DP as the exhaust so i ONCE saw 600F but as soon as i backed off the pedal the dial went back to rest.
But you can trick the gauge (when i had it out) into thinking the temp was super hot and the warning light is super bright.
its my brightest gauge by far and the coolest looking. well...
the oil temp gauge totally disappears when the light turns off...
i duno :P
I'll know how well it really works when i get an exhaust pipe on the car but im thinking 1,000F is going to be the hottest for what im running.
I'll post some vids of all sorts of stuff when i insure it.
ps. pride my self on those drillz skillz! you shoulda seen my block! drilled those steam holes like demz were ma bizatches
whats a temp you should stay away from over 1000
1600F pre-turbine is a good max temp, and should only be sustained for a few seconds or so.
Reply #16February 13, 2009, 01:33:53 pm
  • 3468
    • McScrubbins Body Wash
EGT Guage
« Reply #16 on: February 13, 2009, 01:33:53 pm »
The max i've ever seen was half of that  :lol:
Reply #17February 13, 2009, 05:03:43 pm
EGT Guage
« Reply #17 on: February 13, 2009, 05:03:43 pm »
Quote from: "jtanguay"
1600F pre-turbine is a good max temp, and should only be sustained for a few seconds or so.[/quote]
Thought TD blocks were good up to around 1450? or am i thinking n/a?
1600F IS HOTT LOL
Reply #18February 14, 2009, 12:15:37 am
  • 3468
EGT Guage
« Reply #18 on: February 14, 2009, 12:15:37 am »
Aluminum tends to melt at 660.32 °C. (1220.58 °F)
Keep THAT in mind  :P
Reply #19February 14, 2009, 05:19:59 am
VWSmokr
  • 39
EGT Guage
« Reply #19 on: February 14, 2009, 05:19:59 am »
Obviously, the inconel in turbine wheels starts to deform at about 1600° F. So much to think about! Lol
J.R.
SoCal
J.R.
SoCal
Reply #20February 14, 2009, 08:07:04 am
EGT Guage
« Reply #20 on: February 14, 2009, 08:07:04 am »
don't forget that just because the air is a certain temp, it doesn't mean that the surrounding parts will be at that temp as well... due to the velocity and characteristics of air itself, 1600F for very brief periods, should be okay.
Reply #21February 14, 2009, 08:25:28 am
53 willys
EGT Guage
« Reply #21 on: February 14, 2009, 08:25:28 am »
your brave!! I only dare take mine to 1400*.....anything over that makes me stress!!! :shock:
it's all good until you burn a hole in your piston!! :shock:  :cry:
Reply #22February 15, 2009, 04:00:46 am
ryanp
  • 269
EGT Guage
« Reply #22 on: February 15, 2009, 04:00:46 am »
Is prothe a good person to buy from?
I'm thinking of buying a couple of EGT gauges and boost, oil temp/pressure too.
Ryan
Brand new TDi injector sets:
http://www.vwdiesel.net/forum/index.php?topic=25862.0
Golf Mk2 TDi Van - 250WHP
Reply #23February 15, 2009, 06:07:06 pm
  • 3468
EGT Guage
« Reply #23 on: February 15, 2009, 06:07:06 pm »
've had great success with his EGT, oil temp and boost gauges.
Reply #24February 15, 2009, 07:05:55 pm
camboscams
  • 324
EGT Guage
« Reply #24 on: February 15, 2009, 07:05:55 pm »
I agree, it doesn't go low enough. Plus 60% of the guage is useless, you'll only use up to the 1600* mark, and you won't be in that range everyday anyway... The way i figure i want to only buy a guage with enough numbers i can use after that its useless to me... On postive note, Prothe's guage looks good though :wink:
81' White 1.6l Rabbit 4dr Holseted
72' Ford F-250 390cid
2014 JSW 2.0L TDI Stg 2, CP3 HPFP
Reply #25February 15, 2009, 07:21:30 pm
  • 3468
EGT Guage
« Reply #25 on: February 15, 2009, 07:21:30 pm »
and it's affordable.
and a bright red warning light comes on above 1400f (i think its 1400) i know it comes on if something has happened to the wires (ie. it becomes unplugged or severed from the probe)
Reply #26February 16, 2009, 01:16:19 am
Heavy D
  • 10
EGT Guage
« Reply #26 on: February 16, 2009, 01:16:19 am »
so whats a good gauge to go with that doesn't eat at your pocket
1.6turbo
Reply #27February 16, 2009, 01:53:13 am
james1978
  • 10
EGT Guage
« Reply #27 on: February 16, 2009, 01:53:13 am »
i wouldnt think there is much need to know how low the temps really are
as long as you know soon enough things are going tits up!!
for the price its a billy bargian, as long as it warn you in time, and not post dettonation  :?
something i noticed, was someone saying the egts ran higher with no exaust pipe??
i was gunna do a side exite pippe, which would make it about 2 mtrs total length!
would that be enough for gasses to escape or will i need it longer??
will be without cat ect!!!
thanks
Reply #28February 16, 2009, 03:46:32 am
  • 3468
EGT Guage
« Reply #28 on: February 16, 2009, 03:46:32 am »
Seriously, i dont know why everyone refuses to listen to me. Prothes gauge is responsive. I like it a lot. You can push your foot down and see the dial move accordingly. It can't predict what you're going to do ...
and the gas temp IS NOT the temp of your internals ... It's the temp they WILL be if you hold that temp for long.
I like prothe's gauge. I don't give a hoot what anyone else says who doesn't even use it. :P I do agree that it does go uselessly.  knowing your egt is 600 or 0 doesn't make any difference to me at least. 600 in my books is pretty cold for egt. You have a fair bit of leeway in fueling before you start to venture from 600 to something dangerous. the VDO one is IMHO a perfect egt gauge but it's a lot more money.
PS. egt will never ever be higher with LESS restriction of the exit flow of exhaust gases. That just doesn't make any logical sense what so ever.
You wanna reduce egt and still add fuel? more boost, water/meth injection, a bigger turbo, a BIG downpipe, straight pipe, less bends.
my 2 cents which i've experienced first hand about 5 days ago.
Reply #29February 16, 2009, 07:37:38 am
arb
EGT Guage
« Reply #29 on: February 16, 2009, 07:37:38 am »
Quote from: "libbybapa"
If you do not cool down the turbo to 300°F or so, then the  oil will coke up the bearings and turbo life will be shortened.  Cool down times are often not intuitive.  The simple reason that Prothe's gauge does not have a cool down range makes it useless to me.  I greatly prefer the Westach gauges from Aircraft Spruce for the specific reasons I quoted above.  $80 for the complete kit is a whole lot better deal to me than Prothe's kit.
Andrew
I'm with Andrew on this one.. even with 100% synthetic oil's 450 degrees, you need that range the Westech gives you.
