Author Topic: Rebuilding The Oil Pump  (Read 6493 times)
February 02, 2009, 07:31:31 am
1.6Lmarine
  • 28
« on: February 02, 2009, 07:31:31 am »
So in getting the block in for an evaluation today I took off te oil pump.  I am wondering if there are any particulatiries to the oil pump?  How long do they last?  Can they be rebuilt?  What to look for?
Thanks!
Reply #1February 02, 2009, 08:21:01 am
« Reply #1 on: February 02, 2009, 08:21:01 am »
Just replace it.
The heart of the ENTIRE engine is the oil pump.
Drop Myke_W a PM and buy a new one.
http://vwdiesel.net/phpBB/profile.php?mode=viewprofile&u=798
Reply #2February 02, 2009, 11:46:08 am
rallydiesel
  • 1880
« Reply #2 on: February 02, 2009, 11:46:08 am »
The bentley has specs for the gear lash. There's nothing in them to rebuild. If the lash is past spec then get a new one (36mm gears preferably).
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #3February 02, 2009, 03:05:42 pm
1.6Lmarine
  • 28
« Reply #3 on: February 02, 2009, 03:05:42 pm »
Thanks!  I assume an after-market is available and will check.
Reply #4February 02, 2009, 03:11:24 pm
« Reply #4 on: February 02, 2009, 03:11:24 pm »
Quote from: "1.6Lmarine"
Quote from: "zukgod1"
Just replace it.
Reply #5February 02, 2009, 06:11:34 pm
Rabbit TD
  • 840
« Reply #5 on: February 02, 2009, 06:11:34 pm »
Quote from: "libbybapa"
You can hand lap the cover and remove any scoring.
Andrew
I've done that trick also on some old air cooled VW's to get more oil pressure at idle.  If I remember the paper gasket between the housing and the cover was around 1-2 thousandths and I would just lapp the cover to clean it up and then lapp the housing just to the point where you just couldn't feel any clearance sliding the drive gear in and out with the cover in place without the gasket.  When the gasket was put back in it had enough clearance and did have more oil pressure.  But yes just replace the pump for no more than what they cost.
Reply #6February 02, 2009, 09:11:31 pm
turborabbit
  • 41
Rebuilding the Oil Pump
« Reply #6 on: February 02, 2009, 09:11:31 pm »
Personally, they seem indestructible, but very important. My only bad experience came when I swapped a 1.6T for my 1.6na. I didn't check compression, drove it for three days, lost power on I-44. Then, I checked compression (low-190's) tore down, broke #3 oil nozzle during the rebuild-I fly blind sometimes-took the oil pump off and accidentally discovered the screen was stopped up with fingernail sized paint chips. I'll bet I chekc that screen next time!!-good luck-warren
If "the more you know, then the more you know, you don't know, then I've got a lot to learn, since I'm forgetting what I thought I knew!!
01Dodge TD
81 Caddy TD
84 Winnebago/Renault TD
86Jetta84GolfCaddyCaddyCaddyCaddy
Reply #7February 02, 2009, 09:34:28 pm
Rabbit TD
  • 840
Re: Rebuilding the Oil Pump
« Reply #7 on: February 02, 2009, 09:34:28 pm »
Quote from: "turborabbit"
Hell, I knew everything there was to know that was worth knowing by the time I was 15, but I forgot a lot of it in the past 45 years :lol:
Reply #8February 02, 2009, 10:56:12 pm
Quantum TD
  • 1195
« Reply #8 on: February 02, 2009, 10:56:12 pm »
Just out of curiosity, does any one have the PN for the 36mm geared oil pump?
I've got the following numbers:
Engine Codes 1V, AHU, 1Z (this includes the 1991-1192 ECOdiesel, 1994-1998 Passat TDI, and the 1997-1998 TDI. I'm sure it also includes any AAZ motor as well)
028 115 105 G
And
Engine codes CR, CY, CK, EN, JK, ME, MF, 1V (basically, any transverse-mounted 1.6 NA or TD).
068 115 105 AN
I'm pretty sure the first number is for the 36 mm, and the second number is for the 32mm.
Anyone able to confirm this?
Reply #9February 03, 2009, 12:49:11 am
  • 3468
    • McScrubbins Body Wash
« Reply #9 on: February 03, 2009, 12:49:11 am »
Jesus CHRIST oil pumps are expensive
