Author Topic: 1982 rabbit pickup 1.6d  (Read 5182 times)
January 29, 2009, 02:50:03 pm
fellerhead
  • 1
« on: January 29, 2009, 02:50:03 pm »
where is the thermostat on this motor/or what hose goes there...what temperature activates cooling fan...thank you
just say know
Reply #1January 30, 2009, 09:22:28 pm
« Reply #1 on: January 30, 2009, 09:22:28 pm »
The thermostat is between the bottom of the waterpump and the lower rad hose. You need to remove 2 10mm bolts to get to it. Coolant will get in your eyes....
The rad fan is activated by the switch on the driver side of the rad. It's down near the bottom
Reply #2January 30, 2009, 09:50:12 pm
  • 3468
    • McScrubbins Body Wash
« Reply #2 on: January 30, 2009, 09:50:12 pm »
Quote from: "burn_your_money"
I second that.
