General Information
FAQ/Tech Tips/Please Read First
Any tips for headlight reseal?
Topic: Any tips for headlight reseal? (Read 5346 times)
January 28, 2009, 08:02:22 pm
January 28, 2009, 08:02:22 pm »
one of my headlights leaks water into it and just fires through bulbs like there's no tomorrow.
i tried hot glue (like craft glue but the industrial stuff) and i guess that stopped working? I also tried silicon outdoor use dap but that was poorer than the hot glue. is there somewhere else, other that where the glass bonds to the plastic backing, where the water leaks into sometimes?
anyone have any tips for resealing those bad boys?
Blue 2009 CR140 Jetta CBEA/CJAA. Malone stage 2. EGR/DPF/Exhaust-valve deletes. 2.5" open exhaust. ADP Turbo swap. 1-stage nitrous kit.
THROWN ROD
January 28, 2009, 08:16:03 pm
cyrus #1
January 28, 2009, 08:16:03 pm »
Could you try some epoxy, like a jb weld or something?
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
January 28, 2009, 08:17:30 pm
January 28, 2009, 08:17:30 pm »
Could yes, im mostly asking if there is somewhere else where water likes to get in there like where the light seals to the back of the enclosure. Anyone else have this problem with flooding head lights?
thanks for the reply
THROWN ROD
January 29, 2009, 06:35:52 am
spencebm
January 29, 2009, 06:35:52 am »
new headlight?
Ben Spencer
January 29, 2009, 07:25:01 am
January 29, 2009, 07:25:01 am »
Quote from: "spencebm"
new headlight?
X 2 ^^
It's tough getting them resealed just because it's hard to get it apart.
You can put it in the oven for about 15 min on about 250 ish to soften the glue then you can get a knife in there to cut what's left to remove the Len's then re seal.
BTW, I have not done this. I've only read about this process.
January 29, 2009, 11:54:56 am
79rabbit4dr
January 29, 2009, 11:54:56 am »
Quote from: "Smokey Eddy"
somewhere else where water likes to get in...
if you've got the bulb pulled out, dunk it in water and see where the bubbles come from.
January 30, 2009, 12:19:26 am
January 30, 2009, 12:19:26 am »
Thank you everyone
I will put it in water. find bubbles, JB weld
if that doesn't work ... chisel the JB off, put it in the oven pull it apart, really clean it out then reseal with epoxy.
THROWN ROD
General Information
