Author Topic: 1.8t stock intercooler.  (Read 5565 times)
January 24, 2009, 07:55:51 pm
kaneb
  • 164
    • www.dasdubbers.org
« on: January 24, 2009, 07:55:51 pm »
Hi just wondering if the 1.8t intercooler would be good on a 1.6td?  Or would it be better to just get something bigger?  I don't have the engine completely built yet, but it will be running more ponies then stock for sure!
kane
2004 Tdi sport-daily
1983 Rabbit TD-go kart
www.dasdubbers.org
Reply #1January 24, 2009, 10:00:43 pm
  • 3468
    • McScrubbins Body Wash
« Reply #1 on: January 24, 2009, 10:00:43 pm »
would that be cost effective? :?
im guessing you would get it new?
Reply #2January 25, 2009, 08:13:40 am
dillenger1
  • 777
« Reply #2 on: January 25, 2009, 08:13:40 am »
Im running an IC from a mitsubishi eclipse,works well
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #3January 25, 2009, 01:17:05 pm
spencebm
  • 686
« Reply #3 on: January 25, 2009, 01:17:05 pm »
Quote from: "dillenger1"
I have a spare one of those if you ever need one
Ben Spencer
Reply #4January 25, 2009, 04:31:59 pm
kaneb
  • 164
« Reply #4 on: January 25, 2009, 04:31:59 pm »
No it would be pretty cheap.  We have a vw wreckers in the city and they have quite a few of them.   I just dont want to have something to big you know cluttering up my engine bay.
Just wondering if there would be a gain in a cooler that is this small?
Thanks,
kane
www.dasdubbers.org
Reply #5January 25, 2009, 04:59:38 pm
dillenger1
  • 777
« Reply #5 on: January 25, 2009, 04:59:38 pm »
theres gonna be a gain.Any cooler of temps is a plus.The smaller the cooler the less pressure drop.It just depends on how eficient they are at cooling the air.Bigger isnt always better in intercooling.You can get to big.
Reply #6January 25, 2009, 05:15:45 pm
kaneb
  • 164
« Reply #6 on: January 25, 2009, 05:15:45 pm »
Thats what i thought.
I like the idea of running a smaller intercooler and also running a oil cooler.  I guess though its also i have to get the engine finished and installed and see how the intercooler is, if it doesn't do a good enough job ill find something else. Its just an easy part to get and small so an easier install and not as much clutter.
What size of intercoolers are you all running?
Kane
www.dasdubbers.org
Reply #7January 25, 2009, 05:24:11 pm
dieselherb1
  • 354
« Reply #7 on: January 25, 2009, 05:24:11 pm »
I have both a IC from a 1.9TDI and a IC from a 1.8T. They are about the same size. I plan to use the 1.8T IC in one of my 1.6TD caddies along with the 1.9TDI IC in another caddy.
Reply #8October 22, 2012, 08:18:41 pm
bbob203
  • 1789
Re: 1.8t stock intercooler.
« Reply #8 on: October 22, 2012, 08:18:41 pm »
Does anyone have any more info on running a 1.8t intercooler with a 1.6?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #9October 22, 2012, 08:26:12 pm
« Reply #9 on: October 22, 2012, 08:26:12 pm »
the stock 1.8T intercoolers kinda suck.. they are really thick, and hard to mount in a mk1 or mk2/3 without moving stuff..
there are much better options out there..
myself personally, i dont even consider plastic intercoolers an option anymore.. the plastic tanks split too easy..
go with something all metal, like a supra intercooler, or starion, or eclipse, or ford probe, or anything like that..
all those that i listed, are 100x better than a 1.8T side mount cooler..
Reply #10October 22, 2012, 08:34:10 pm
bbob203
  • 1789
« Reply #10 on: October 22, 2012, 08:34:10 pm »
Can i keep my ac and still be able to run one up front?
03 Jetta wagon TDi
Reply #11October 22, 2012, 08:36:20 pm
bbob203
  • 1789
03 Jetta wagon TDi
Reply #12October 22, 2012, 09:47:07 pm
« Reply #12 on: October 22, 2012, 09:47:07 pm »
you need something REALLY THIN to be able to retain your stock a/c
something like a supra intercooler.. they are very thin..
so are ford prob intercoolers.
Reply #13October 23, 2012, 01:27:25 am
CrazyAndy
  • 739
« Reply #13 on: October 23, 2012, 01:27:25 am »
http://www.ebay.com/itm/2g-DSM-eclipse-talon-95-99-Turbo-stock-oem-side-mount-intercooler-SMIC-/360499142842?fits=Model:Eclipse&hash=item53ef6c60ba&item=360499142842&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
Something like this?
I don't even see how that could be integrated properly.  It looks like one of the outlets is smaller then the other.  How bizzare!
And kaneb, as far as all these IC talks, what chassis application are you talking about?  MK1?  2?
Which do the Supra/Probe ICs fit best in?
Reply #14October 23, 2012, 08:29:55 am
bbob203
  • 1789
« Reply #14 on: October 23, 2012, 08:29:55 am »
mkdos
03 Jetta wagon TDi
S-PAutomotive.com
