Author Topic: Changing Lights in temp/climate control face thing  (Read 4178 times)
January 23, 2009, 03:19:50 pm
  • 3468
    • McScrubbins Body Wash
« on: January 23, 2009, 03:19:50 pm »
I'm not sure how to go about this... the back plate seems to be glued on?
If i put it in the oven at a low temp will that free the glue?
I know people have put LED's back there but i just want to know how to get it open!
Thank you for your time!
Reply #1January 23, 2009, 03:43:17 pm
« Reply #1 on: January 23, 2009, 03:43:17 pm »
It doesn't open unfortunately... it's glued together and will probably break if you try to disassemble... $$$$ at the dealership too.. coincidence??!! ;-)
And of course if you look for 'em at a junkyard they are already gone... or are just as burnt out as yours are.
Vortex is fulla threads on adding LEDs, but the basic idea is that you use a large drill bit to drill out where the current wiring harness socket is... drilling thru the prongs of the socket and into the lightbulb itself (wear safety glasses)... then glue in a light bulb or a couple of LEDs.
Reply #2January 23, 2009, 03:49:27 pm
  • 3468
« Reply #2 on: January 23, 2009, 03:49:27 pm »
Ahhh and then have your own wiring and stuff. I see.
Perhaps that job is for another day then :) im just doing my speedo cable right now.
 thanks for the prompt reply Vince.
Another question, how full should my manual trans be? I took the cable out at the trans side and i can see the fluid down there but how full should it be? I have a feeling it could do with a top up? The colour is concerning too its like a brown colour but i know that trans fluid is usually orange so that's not a big deal. it's not black or anything. what is the fill mark? sort of speak
Reply #3January 23, 2009, 03:55:14 pm
53 willys
« Reply #3 on: January 23, 2009, 03:55:14 pm »
I took mine apart....just this week.
you just need to be VERY VERY patient!!
I cut the glued seems with a hobby knife/exato...then use a VERY thin flat blade driver to "peel it apart"...DONT GET GREEDY!! or you will break it.
I'm doing mine just like this guy..but mines gonna say "1.6TD" instead of "GTI" :wink:  :twisted:
http://forums.vwvortex.com/zerothread?id=4206297
Reply #4January 23, 2009, 04:27:33 pm
  • 3468
« Reply #4 on: January 23, 2009, 04:27:33 pm »
oh that's awesome! thanks for the thread. definitely doing that!
Reply #5January 23, 2009, 04:27:42 pm
cyrus #1
  • 360
« Reply #5 on: January 23, 2009, 04:27:42 pm »
Here is a picture of mine in my gasser.
As Vince mentioned, you need to be super careful pulling it apart.  I didn't break mine but it still didn't go back together quite as nicely as it did from the factory.  I found a larger LED (5mm I believe) that fit in the stock light location perfectly.  Then I soldered on tabs so I can plug it in the factory wiring harness without modification.
The only problem with the LED is that they don't spread the light very well.  The beam is intense but very focused.  That's why it's brighter on the left where the light is located.  If you took a bit of sandpaper and roughed up the LED or light diffusing panel I think you could get it a bit better though.
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #6January 23, 2009, 04:58:20 pm
  • 3468
« Reply #6 on: January 23, 2009, 04:58:20 pm »
Ahhhh thanks cody! this is food for though.
from hong kong but what ever. pretty good deal on LEDs here
http://cgi.ebay.ca/5mm-blue-LED-20-pcs-pack-FREE-SHIPMENT_W0QQitemZ380098657618QQcmdZViewItemQQptZRadio_Control_Parts_Accessories?hash=item380098657618&_trksid=p3286.c0.m14&_trkparms=72%3A1215|66%3A2|65%3A12|39%3A1|240%3A1318
php doesn't like that link otherwise i'd link it. gotta copy and paste, sorry fellas
Edit: meh, that part that is linked is okay.
Reply #7January 23, 2009, 05:10:07 pm
53 willys
« Reply #7 on: January 23, 2009, 05:10:07 pm »
I buy my LEDs from these guys..
always FAST shipping..but yeah you will pay a little more then the HK LEDs
SuperbrightLEDs stocks bulbs for our dashes..they are SWEET!!
they also have most aftermarket gauge bulbs in the LED verity as well!!
they have LED#74 bulbs that plug right into the heater control broad..
http://www.superbrightleds.com/led_prods.htm
Reply #8January 23, 2009, 05:23:17 pm
Rabbit TD
  • 840
« Reply #8 on: January 23, 2009, 05:23:17 pm »
Quote from: "Smokey Eddy"
Maby using a hair dryer to warm it up a little when you start prying it apart so it won't crack as easily. :idea:
Reply #9January 23, 2009, 05:38:58 pm
  • 3468
« Reply #9 on: January 23, 2009, 05:38:58 pm »
Excellent advice Rabbit!
I've got it apart now but im having issues with getting the burnt out bulb ... out of the plastic Any ideas? :P
I've decided that for now i just want to replace the bulb. I'll change all the lights to LED's another time.
Reply #10January 23, 2009, 06:47:49 pm
  • 3468
« Reply #10 on: January 23, 2009, 06:47:49 pm »
If you've got a dremel tool and are pretty good with a fine paint brush you can do the method 53 willy's posted without ordering a special plastic piece.
Use a dremel to get the LED's into the shape you want and to cut the indents into the clear plate!
Also, instead of laser engraving you could use a piece of paper, print it black with white font on it of what you want with a photo printer at the highest quality, then use clear glue to stick it to the plastic piece. There you go, won't look as good as laser engraving but if that isn't an option for you im sure my method might be?
Reply #11January 23, 2009, 06:57:20 pm
« Reply #11 on: January 23, 2009, 06:57:20 pm »
Quote from: "53 willys"
Yeah, saw that tread.. that's some nice work for sure.... and the whole idea of laser engraving has lots of possibilities elsewhere.
Among other things, I'm kinda jealous of someone with enough time to spend that much effort on one detail. :cry:  :wink:
Reply #12January 23, 2009, 07:05:17 pm
  • 3468
« Reply #12 on: January 23, 2009, 07:05:17 pm »
I'm doing it right now and with that guide its REALLY easy and takes no time what so ever so long as you can get that piece apart. I'm basically done and i've been farting around on the computer all day doing other stuff. I also fixed my speedo and painted a bunch of stuff.
Like i said if you have a dremel tool you can do the LED swap no prob.
