Author Topic: Inline pump  (Read 2876 times)
January 22, 2009, 10:24:22 am
95ctd
Inline pump
« on: January 22, 2009, 10:24:22 am »
Is any one know of anyone running an inline style injection pump on performance type engine? Just curious seems to me it would flow alot of fuel probably too much.
Thanks Joe
Reply #1January 22, 2009, 11:32:57 am
Re: Inline pump
« Reply #1 on: January 22, 2009, 11:32:57 am »
Quote from: "95ctd"
Thanks Joe
Giles does those i'm sure.  give him a call - check vendors section for contact info.
Reply #2January 22, 2009, 01:00:31 pm
Inline pump
« Reply #2 on: January 22, 2009, 01:00:31 pm »
I don't see a reason to re-engineer the current system. The VE pump is capable of delivering more fuel than you can burn once you install a larger pump and mess with the governor.
I had mine flow tested at a local shop and the shop owner called me to ask what the he** I had done to my pump.. It was delivering twice the fuel it was set at from the factory before the boost was applied..
When I was running that pump I could hit 40psi  :shock: Poor rods were crying I'll bet...
Reply #3January 23, 2009, 05:47:40 pm
AdAm84
Inline pump
« Reply #3 on: January 23, 2009, 05:47:40 pm »
I have thought about this too. But it just doesn't seem worth while when the VE was used on the 4BT's. So, if you use those internals you should be able to push way more than enough fuel. But, I have looked at teh possiblity of using a small Bosch A pump. The P-pump would just be overkill.
Reply #4January 23, 2009, 09:10:22 pm
Turbinepowered
  • 1206
Inline pump
« Reply #4 on: January 23, 2009, 09:10:22 pm »
Quote from: "zukgod1"
Cryin... cryin for some nice, forged rods and more boost...  :lol:
Reply #5January 23, 2009, 09:49:14 pm
Inline pump
« Reply #5 on: January 23, 2009, 09:49:14 pm »
Quote from: "Turbinepowered"
and a girdle!
oh and if trying to mount an inline pump to a vw 4 cyl motor, forget it.  wayyyyyyyy too much crap to deal with to make it remotely worthwhile.
if you have the money to blow and just want something unique, then go for it.
what types of motors came with a 4 cyl inline pump? did the 1.9L mercedes diesels come with an inline pump???
Reply #6January 23, 2009, 11:45:27 pm
Turbinepowered
  • 1206
Inline pump
« Reply #6 on: January 23, 2009, 11:45:27 pm »
Quote from: "jtanguay"
2.4 Mercedes nonturbo engines in the seventies...
Reply #7January 24, 2009, 12:03:35 am
Rabbit TD
  • 840
Inline pump
« Reply #7 on: January 24, 2009, 12:03:35 am »
HaHa, how did the pistons hold up, did it do any damage to them or haven't you had it apart since then?  I'm just wondering what it takes to hurt one of these little creatures :D
