Author Topic: Larger Turbo?  (Read 1877 times)
January 20, 2009, 07:37:51 am
Laurie
  • 4
Larger Turbo?
« on: January 20, 2009, 07:37:51 am »
Hello my turbo has gone on my 1.9 TD AAZ 1996 passat B4, since its broke I thought I would replace it with a larger turbo like a garret T3 from the mk2 golf diesel turbo and do a few other mods like boost pin etc.
I just wanna know how I would go about putting this turbo on, is it a direct change or do I need a different manifold and boost pipe etc?
Cheers
Reply #1January 20, 2009, 09:46:16 am
g-spec
  • 289
Larger Turbo?
« Reply #1 on: January 20, 2009, 09:46:16 am »
If you had the K14 as a stock turbo it will bolt up no problem, the intake doesnt fit after....so you would have to get a 1.6 intake. Inlet on the turbo is bigger.
You will also have to cut one little piece of the intake manifold, and the oilreturn line does not match up 100%. Some modification will be required....I just made a new stainless line 3/4inch ID, goes into the pan. Stock location blocked.
If you have a K03 turbo then you will have to change the exhaust manifold aswell, Along with all the other mods listed above.
Reply #2January 21, 2009, 12:44:59 am
Laurie
  • 4
Larger Turbo?
« Reply #2 on: January 21, 2009, 12:44:59 am »
how do you know which turbo you have?
