Author Topic: testing glow plugs  (Read 13245 times)
January 19, 2009, 03:08:37 pm
steve6
  • 66
testing glow plugs
« on: January 19, 2009, 03:08:37 pm »
can someone tell me how I can test these, my car wont start in the cold anymore :X
Reply #1January 19, 2009, 03:20:49 pm
Re: testing glow plugs
« Reply #1 on: January 19, 2009, 03:20:49 pm »
Quote from: "steve6"
sure fire way is to take them out and energize them.  does it crank fast enough?
Reply #2January 19, 2009, 03:30:37 pm
Jettagli16v
  • 344
testing glow plugs
« Reply #2 on: January 19, 2009, 03:30:37 pm »
I have been wondering about using an IR thermometer to check each individually.
If you were to keep your IR dot on the end of each plug (Or maybe on the head right where they screw in?)
would you see a temp increase at each plug
(and assume they are working, or not, based on temp rise)?
If the plugs run until the cylinder head coolant temp sensor sees a rise in temp, one would think you could see this rise on the head itself.
Thanks!
-Brad
Reply #3January 19, 2009, 05:32:01 pm
steve6
  • 66
« Reply #3 on: January 19, 2009, 05:32:01 pm »
Quote from: "jtanguay"
ok, so they have to come out? no resistance test or anything that can be done?
The car starts if I put the block heater on it... its got a brand new energizer battery.... The glow light plug never turns off when turning the key on.... I assume they arnt heating up enough.
Reply #4January 19, 2009, 05:39:41 pm
cyrus #1
  • 360
testing glow plugs
« Reply #4 on: January 19, 2009, 05:39:41 pm »
You can check the resistance to see if they are burned out.  Unfortunately, to do so you still need to take the bus bar off and that's most of the work anyhow.
Did this happen all of a sudden or gradually?  If you have a multimeter, you can start by checking the bus bar to see if it's actually getting voltage.  Based on your description of the light never going off, it sounds like you could have a relay problem.
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #5January 19, 2009, 06:01:05 pm
testing glow plugs
« Reply #5 on: January 19, 2009, 06:01:05 pm »
Here's an overview of one possible troubleshooting procedure fwiw, assuming all you own is a testlight or cheap multimeter:
1) start by confirming that the glow plugs are getting power.  Sadly the light on the dash has nothing to do with power to the glowplugs. Multimeter or test light to the wide copper buss bar... turn the key on... you should have power for 5-20 seconds depending on engine temp.
2) if you *don't* have power, go upstream to the glowplug fuse... it's in a small plastic box on the firewall next to the brake booster.  It loves to develop hairline cracks, so either test both sides with your multimeter/testlight or remove it and see if it falls apart in your hands.
3) if you still don't have power your next stop is the glowplug relay.... tall relay-looking device mounted on the fuse panel.  Not easy to troubleshoot unless it looks physically damaged... swapping out with a good one is the quickest way
If in (1) you determined you are getting power to the glowplugs then they need to be tested individually.  Unfortunately as they are wired in parallel the buss bar needs to be removed... not a fun job but it can be done. 8mm wrench and a magnet on a stick are your friends here.  With the buss bar removed you can check for continuity at each plug individually... they usually fail open.
If you own a heavy duty current meter you can test the plugs pretty well with the buss bar on... I use a cheap NAPA meter:
Will all 4 plugs in working order you should see 50-60 amps dropping to 35-40 once they warm up a bit (assuming a nice strong battery). Anything less suggests one or more plugs have gone to meet their maker.  Note that I'm giving pretty wide current readings... cheap gauges are not that accurate, different plugs draw different currents, and initial battery voltage has an effect as well.
One other suggestion:  they are not that expensive *and* seem to go in short succession, so I always replace all 4 at once.... such a pain to get the buss bar off I only want to do the job once any given winter. :wink:
I keep meaning to do a HOW-TO on this one... 'course I'd need to track down a stock engine since mine have been pimped and would not make for good pictures. ;-)
Reply #6January 19, 2009, 06:18:15 pm
commuter boy
  • 277
testing glow plugs
« Reply #6 on: January 19, 2009, 06:18:15 pm »
I've always found the fastest way is to pull the injectors and look down the hole to see if they glow.
The plugs themselves are fiddly to get in and out (especially the one behind the fuel pump) but the injectors are just the lines, four injectors and replace the heat shields for $2.  It probably helps that I've got the curved Hazmet injector line wrench from Metalnerd.
Reply #7January 19, 2009, 06:22:11 pm
testing glow plugs
« Reply #7 on: January 19, 2009, 06:22:11 pm »
Quote from: "commuter boy"
Oh sure... thanks for reminding me... Santa did not put that beauty in my stocking this year despite the nice long letter I wrote him. :cry:  :wink:
Reply #8January 19, 2009, 06:31:01 pm
commuter boy
  • 277
testing glow plugs
« Reply #8 on: January 19, 2009, 06:31:01 pm »
My dad the VW mechanic was out for a visit and got to use one for about 5 minutes.  He looked at me like Old Yeller when I went to put it back in the toolbox so I just handed it to him and bought another one.   Just get it.
Reply #9January 19, 2009, 09:01:35 pm
Rabbit TD
  • 840
testing glow plugs
« Reply #9 on: January 19, 2009, 09:01:35 pm »
Quote from: "Vincent Waldon"
I've often read that you can test them all in the car with an OHM meter.  Unhook the bus-bar and check the reading on the easiest one you can get to and if it is good, hook the bar back up and take a reading of them all in series and if they are all good the number will be in the neighorhood of 4 times higher than the individual one read, or in multiples of the known good one telling you how many are bad.  If any are bad then you have to test them individualy.  If they are all the same brand plug and type they should all read equal or pretty close. :)
Reply #10January 19, 2009, 09:25:24 pm
testing glow plugs
« Reply #10 on: January 19, 2009, 09:25:24 pm »
Well, they are about an ohm each, so the 4 in parallel is 1/4 of an ohm...  a sensitive ohmmeter could probably pick that up, although at that end of the scale the leads and fuse of the ohmmeter probably enter into it as well.  Mine reads about 8/10 of an ohm with the leads shorted.  Temperature of the plugs would also enter into it... there's a whole school of diesel tuning based on that.
Always many ways to skin the proverbial feline, heh?! :wink:
Reply #11January 20, 2009, 06:53:43 am
steve6
  • 66
testing glow plugs
« Reply #11 on: January 20, 2009, 06:53:43 am »
Quote from: "cyrus #1"
I was always parking it in my garage with the block heater since the beginning of winter, and at work it was underground parking, one day I parked it outside and wouldn't start, I had to get it towed home, block heater on it the next day and it started.  I have a feeling a couple glow plugs are working.  The glowplug light.. it used to shut off after about 60 seconds, but in this extreme cold snap we've been having, I havn't seen it turn off yet..
I knew about this long ago, just addressing now... aint no worries the other jetta starts in -30c without issue. but it has a ***ty transmission  :cry:
Reply #12January 20, 2009, 06:54:44 am
steve6
  • 66
testing glow plugs
« Reply #12 on: January 20, 2009, 06:54:44 am »
stupid double post
and I have a brand new Energizer battery from walmart.. less than 2 months old.
I was getting lots of cranking.. lots of smoke, just no fire  :lol:
Reply #13January 20, 2009, 09:41:01 am
turborabbit
  • 41
testing glowplugs
« Reply #13 on: January 20, 2009, 09:41:01 am »
All that stuff about ohms and such is making my head hurt. I "want" that stuff, but you "need" a battery charger and a compression tester. Always know your  compression values and the battery charger will test the glowplugs. They will get red hot if they are good, toss them if they don't.
With an inexpensive product warantee, Pull-a-part gives me an endless supply of glowplugs. It sounds like you need at least 2 if not 3. Goodluck-warren :mrgreen:
If "the more you know, then the more you know, you don't know, then I've got a lot to learn, since I'm forgetting what I thought I knew!!
01Dodge TD
81 Caddy TD
84 Winnebago/Renault TD
86Jetta84GolfCaddyCaddyCaddyCaddy
Reply #14January 20, 2009, 10:07:38 am
steve6
  • 66
Re: testing glowplugs
« Reply #14 on: January 20, 2009, 10:07:38 am »
Quote from: "turborabbit"
Diesel blocks from the vw's never make it to the wreckings yards around here... engines always get pulled first.   :x
Ill just order a few and change atleast the easy 3.. lol.. $20 a piece  :shock:
