Author Topic: pcv valve  (Read 5009 times)
January 17, 2009, 10:19:32 am
shopro88
  • 8
pcv valve
« on: January 17, 2009, 10:19:32 am »
Hi, I have a 91 jetta ecodiesel. few weeks ago I noticed I was leaking some oil. I took it to the shop and my mechanic said the head gasket was leaking, so I told him to go ahead and replace it. got the car back and it still is leaking a good bit of oil, even worst then before. my dad said that it could be the pcv valve isn't working correctly and is allowing pressure to build in the block. is it possible for seals to leak from pressure in the block, caused by the pcv valve?
Reply #1January 17, 2009, 02:53:02 pm
dillenger1
  • 777
pcv valve
« Reply #1 on: January 17, 2009, 02:53:02 pm »
definetly!ty blowing out your crank breather/oil stop screen on the valve cover.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #2January 17, 2009, 04:46:33 pm
  • 3468
    • McScrubbins Body Wash
pcv valve
« Reply #2 on: January 17, 2009, 04:46:33 pm »
With Dilly on this one.
wash it out with solvent perhaps?
ps. its that meshy thing in the valve cover that dilly mentioned.
if you're very mechanically savvy changing the piston rings would also help. But since you got a mechanic to change your HG/look for oil leaks im thinking that may possibly be a big job for you. (tools wise)
Reply #3January 17, 2009, 08:51:59 pm
Rabbit TD
  • 840
pcv valve
« Reply #3 on: January 17, 2009, 08:51:59 pm »
Quote from: "Smokey Eddy"
Do the 1.9's even have a pcv valve or is it just vented, I've never worked on anything other than the 1.5's and 6's.
Reply #4January 18, 2009, 07:19:24 am
pcv valve
« Reply #4 on: January 18, 2009, 07:19:24 am »
1.9 IDIs have the PCV valve, not sure about TDIs.
The shop might have messed up putting the valve cover on, or it may be warped. Take it off and check it with a straight edge and also inspect the gasket. I'd recommend upgrading to the ruber valve cover gasket.
Have you been able to see where it is leaking from?
Reply #5January 18, 2009, 07:38:09 am
Rabbit TD
  • 840
pcv valve
« Reply #5 on: January 18, 2009, 07:38:09 am »
Quote from: "burn_your_money"
Is there a rubber  valve cover gasket for the 1.6 and where do you get them :?:
Reply #6January 18, 2009, 09:23:17 am
cyrus #1
  • 360
pcv valve
« Reply #6 on: January 18, 2009, 09:23:17 am »
Quote from: "Rabbit TD"
Myke W on the forum has them. As does German auto parts, etc. I've used it without problem on all of my cars. You have to replace the studs as well  but the gasket itself is one piece so it's fairly foolproof.  :D
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #7January 18, 2009, 10:05:35 am
pcv valve
« Reply #7 on: January 18, 2009, 10:05:35 am »
Giles can also get them, although I don't think we can get the stock studs anymore. We can definitely get suitable replacements.
It's the valve cover gasket and studs for a mk3 ABA motor. The G60 engine also used the rubber gasket.
Reply #8January 18, 2009, 05:30:09 pm
shopro88
  • 8
pcv valve
« Reply #8 on: January 18, 2009, 05:30:09 pm »
its now in the shop to get the front main seal, not a big job plus hes goin to do it for free. I cleaned the pcv when I first got the car and was going threw it, and the pcv was checked out again by my mechanic. the car only has 140,000 miles on it, ya think it would need rings? no blue smoke and very little oil consumption.
Reply #9January 18, 2009, 06:14:53 pm
  • 3468
pcv valve
« Reply #9 on: January 18, 2009, 06:14:53 pm »
I have one i don't need anymore. It's in perfect shape. Pm me.
I also have bolts that fit the holes and thread pitch. ground to the right lengths for the holes. they are a lot nicer than using studs fumbling with the little nuts and all that rubbish (i find anyways). I'd send them to you with the gasket if you want mine. It's used obviously but it still is in perfect working order. Never leaked.
Reply #10January 18, 2009, 06:23:38 pm
  • 3468
pcv valve
« Reply #10 on: January 18, 2009, 06:23:38 pm »
Quote from: "shopro88"
Rings are always a bit of a gamble unless the oil consump is through the roof. The oil can either get past the valve stem seals or the rings. usually its valve stem seals. Bad rings would give poor compression but you'd need a comp tester. Unless it burns really white even when warm.... white burning when warm is incomplete diesel burn.
Reply #11January 19, 2009, 08:06:24 pm
Rabbit TD
  • 840
pcv valve
« Reply #11 on: January 19, 2009, 08:06:24 pm »
My 1.6 N/A burns oil mainly when idling for a while like a long stop light or something like that, you can tell by the smell it's oil, 15/40 Shell and leaves a good bit of blue smoke when you start off even easy  after idling at the light.  The motor was rebored .020 and  the head rebuilt at the same time supposedly with new seals about 30,000 ago. The motor runs and starts exellent and gets 50-52 mpg at around 65 mph and had 425 on all cyls when I put it together.  Do you think this is going through the valve guides?  It doesn't even smoke blue when I take off hard, just black and again this little motor couldn't run any better, if it is the valve guide seals are there some better than others.  Companies have changeds so much over the years and I don't know what's good and what's junk anymore on a lot of stuff.  I have a hard time believing it's the rings on this motor the way it runs and starts.
Reply #12January 19, 2009, 09:13:49 pm
cyrus #1
  • 360
pcv valve
« Reply #12 on: January 19, 2009, 09:13:49 pm »
Sounds like valve stem seals.  They were gone on my gasser and I was using like 4-5 liters between oil changes.  Replace the valve stem seals and that went down to about .5 liters.  It's possible the valve seals were damaged during installation.  They should last longer than 30,000.  :?
Cody
2002 Jetta TDI
