Author Topic: AHU engine crankshaft in 1Z engine?  (Read 11262 times)
Reply #15February 02, 2009, 02:37:08 pm
jiggs
  • 41
« Reply #15 on: February 02, 2009, 02:37:08 pm »
the spacings betwen the fixation points, and the clearence to the timming sprocket...
well... thanks for the inputs you guys only by milling you can adapt...
too much expensive, got a good as new, for 200 eur, plug and play
and there ya go, gtd aaz on the road.
Dark Projects...
Mecānica Auto e Performance...
Reply #16February 04, 2009, 01:14:52 pm
rallydiesel
  • 1880
« Reply #16 on: February 04, 2009, 01:14:52 pm »
This is confusing. So do you have a 1Z, an AAZ, or a GTD? Because a GTD is a 1.6 and the 1Z, AHU, AAZ cranks will definitely not fit.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #17February 04, 2009, 02:28:06 pm
blackdogvan
  • 574
« Reply #17 on: February 04, 2009, 02:28:06 pm »
If it helps I have a AHU/1Z crank in my AAZ. I did this to solve the crank nose issue for good. Finding a crank at a reasonable prie wasn't too hard. I believe they are the same till after 1998 when they changed the block to the ALH. Ask Jimfoo, he'll tell you all about AAZ blocks being identical to 1z AHU blocks.
1991 Vanagon 1.9 mTDI
Reply #18February 04, 2009, 02:37:02 pm
rallydiesel
  • 1880
« Reply #18 on: February 04, 2009, 02:37:02 pm »
Exactly, that's why I think the OP got his codes mixed up. I assume he actually has a 1.6 GTD.
Reply #19May 28, 2009, 04:14:52 am
jiggs
  • 41
Re: AHU engine crankshaft in 1Z engine?
« Reply #19 on: May 28, 2009, 04:14:52 am »
bad miss understanding, it was a aaz engine with broken crankshft, not mine.
what the owner told me was that the 1Z didn“t fit. so he got an ahu engine and replaced all the components and added the electronics.
its running fine now...
sorry about the lag...
Dark Projects...
Reply #20May 28, 2009, 03:49:09 pm
« Reply #20 on: May 28, 2009, 03:49:09 pm »
yea... PD100 rods work on the AAZ engine... so i'd imagine that there is a very good chance that the crankshaft would fit also.
