Author Topic: Boost Pin/What's all needed??  (Read 5286 times)
January 13, 2009, 12:04:22 pm
ein bora
  • 377
« on: January 13, 2009, 12:04:22 pm »
Thanks to the help of a couple of fellow enthusiast I'm finally in the process of doing the boost pin upgrade on my 1.9TD. Is there anything else that I'm going to need to do this properly other than the rover pin??
Thanks.
If you can't take advice - then you can't be helped!
Reply #1January 13, 2009, 01:16:53 pm
ein bora
  • 377
« Reply #1 on: January 13, 2009, 01:16:53 pm »
Quote from: "libbybapa"
Yes, from what I've seen you need several other parts, depending on how your AAZ pump is currently set up.  You also need the rover pin spring, the starwheel, the little starwheel metal clip thingy (technical term) and maybe the nylon washer.  You will want to measure the diameter of the pins and make sure they are the same.  If they aren't, then you will also need the threaded tube that the pin slides in and the locknut that keeps it in place.
HTH,
Andrew
Yikes!! I had trouble enough just finding the pin let alone all that other stuff. Where do I begin to look??  :?:
Reply #2January 13, 2009, 02:38:00 pm
ein bora
  • 377
« Reply #2 on: January 13, 2009, 02:38:00 pm »
In a used pump...
Pull the four screws from the aneroid top and snap a picture of what's in your current pump and the info provided will be more accurate.
Andrew
Thanks, I won't be able to take any pictures until tomorrow but for today I can tell you that's it a 94 Canadian 1.9 TD. If that helps any??
Reply #3January 13, 2009, 04:17:39 pm
« Reply #3 on: January 13, 2009, 04:17:39 pm »
Nope, unfortunately, Canada got multiple different IP versions on the AAZ engine.
The key thing to confirm before you go any farther is if it even has a boost pin... one version of the early AAZ engine (common on early Canadian Passats and possibly MK3s) did not, and if this is the case you'll want to track down a whole new lid.
The no-boost-pin version looks like this:
Flat top where the LDA normally sits... no boost pin nor any of the other internals required to "read" it.
Reply #4January 14, 2009, 02:45:31 pm
ein bora
  • 377
« Reply #4 on: January 14, 2009, 02:45:31 pm »
In a used pump...
Andrew
Way to cold to take anything apart today and it's suppose to get even colder tonight. I did mange to take a couple of pictures though.
http://img.photobucket.com/albums/v518/truszip/parts002-1.jpg
Hopes this helps some? Thanks.
Reply #5January 14, 2009, 06:10:26 pm
ein bora
  • 377
« Reply #5 on: January 14, 2009, 06:10:26 pm »
"joke pin"??
Just my luck! I gather I will be farther ahead looking for a dilapidated pump for parts. What would be a fair price to have to pay for something like that?? Any idea's??
Reply #6January 14, 2009, 06:13:28 pm
Dirtrag2
  • 298
« Reply #6 on: January 14, 2009, 06:13:28 pm »
contact Gilles in the vendor's section he may be able to help.
...Darcy
'97 Jetta 1.9TD ( dirtrag2 )
'88 Fox Wagon ( projekt Dirtrag 3 )
Reply #7January 14, 2009, 08:24:29 pm
blackdogvan
  • 574
« Reply #7 on: January 14, 2009, 08:24:29 pm »
Who says you have to add a star wheel & clippy thing? Its not an eco, he should be fine with the pin & spring, no?
1991 Vanagon 1.9 mTDI
Reply #8January 16, 2009, 09:36:41 pm
« Reply #8 on: January 16, 2009, 09:36:41 pm »
I don't have a starwheel or clippy thing, though I did get a much stronger spring. I don't smoke like a freight train either.
Reply #9January 17, 2009, 03:46:26 am
dillenger1
  • 777
« Reply #9 on: January 17, 2009, 03:46:26 am »
HTH,
Andrew
I took my washer out.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #10January 17, 2009, 11:19:41 pm
Clintwalker85
  • 91
« Reply #10 on: January 17, 2009, 11:19:41 pm »
i have the same inection pump as that...now where is the screw to turn up the fuel????sorry i'm new:P
Reply #11January 18, 2009, 10:09:13 pm
ein bora
  • 377
pimp pic
« Reply #11 on: January 18, 2009, 10:09:13 pm »
I found a guy selling a pump, apparently it's a 1.6 td - can anybody verify that for me and is this what I'll need to do the boost pin mod??
Thanks.
Reply #12January 19, 2009, 11:36:03 am
ein bora
  • 377
« Reply #12 on: January 19, 2009, 11:36:03 am »
Reply #13January 19, 2009, 12:56:06 pm
blackdogvan
  • 574
« Reply #13 on: January 19, 2009, 12:56:06 pm »
Ya looks good! You might want to pull your pin out & check the diameters. Whats he asking for it?
