Author Topic: Diesel Tach  (Read 3977 times)
January 10, 2009, 03:47:44 pm
boosted_diesel_84
  • 216
Diesel Tach
« on: January 10, 2009, 03:47:44 pm »
So i been doing a lot of researching and looking thru old posts about adding a vw cluster with a tach to run off W terminal,. i am still confused as to what i actually need to do, i have an 84 jetta TD and a cluster from an 86 cabriolet, how do i make this work, and how do i swap the glow plug light into the cluster,
yes i have searched and just found a bunch of ramblings, i need to find like a nice step by step, with pics. anyone help? thanks in advance!!
-Jack-
.0020 over block,balanced,blueprinted,8lb flywheel,Stage 2 clutch,ported and ceramic coated head manifolds,turbo,pistons, SS valves, PP 2.5in DP,Intake, 3" ex.GTD nozzles, Built pump, windage tray,36mm pump,ARP Studs.etc.My build thread http://www.vwdiesel.net/forum/index.php?topic=15461.0
Reply #1January 10, 2009, 04:12:55 pm
BellCityDubber
  • 251
Diesel Tach
« Reply #1 on: January 10, 2009, 04:12:55 pm »
just ploping in a gasser tach on the diesel W terminal wont work out very well.... the gasser tach needs modifications to read the w terimnal signal properly.
Reply #2January 10, 2009, 07:28:20 pm
Diesel Tach
« Reply #2 on: January 10, 2009, 07:28:20 pm »
http://vwdiesel.net/phpBB/viewtopic.php?t=6477&highlight=gasser+tach
Read this. It is about a vanagon I believe, but Vince and some others go on about how to do this mod. I'm sure this will get you close. If not I would PM Vince and see if he could do something for you.
Reply #3January 10, 2009, 09:36:25 pm
Rabbit TD
  • 840
Re: Diesel Tach
« Reply #3 on: January 10, 2009, 09:36:25 pm »
Quote from: "boosted_diesel_84"
-Jack-
There is another alternative and I have been thinking about it myself.  There is a guy at 4crawler.Com/Diesel/CheapTricks/index.shtml who has made a regular gas tach. work on a diesel using a photocell in the timing belt cover with the breaker mounted on the injector pump pulley.  He has a kit for $40 to do this and other options including a tach as well.  I don't know if he still sells them or not for that price or even at all though but his site is still there, again I don't know how to do the link post thing.  It really doesn't look to complicated and you can use about any tach you want.  I'm gonna look into it myself after I get this motor in, Spring if not sooner :D
Reply #4January 13, 2009, 09:42:28 am
TedV
  • 182
Diesel Tach
« Reply #4 on: January 13, 2009, 09:42:28 am »
I did the circuit on 4crawlers web page.  Purchased the parts from digikey.  Enough to do a few of them since a couple of friends wanted to try them too.  With the 4 crawler circuit it mimics a gas tach signal so I can use regular gasser shift lights and accesories.  To me that was easier than reworking the tach.  I rework surface mount soldered boards at work so the through hole soldering and circuit was easy for me also.
Reply #5January 13, 2009, 09:56:40 am
arb
Diesel Tach
« Reply #5 on: January 13, 2009, 09:56:40 am »
You have have a copy of the post on http://www.4crawler.com/Diesel/CheapTricks/Tachometer/index.shtml
?  It appears to be gone.
Reply #6January 13, 2009, 02:32:47 pm
TedV
  • 182
Diesel Tach
« Reply #6 on: January 13, 2009, 02:32:47 pm »
I was going to post the link, but it's the same one you have, and it worked for me.   :?
clean out cookies on computer?  or maybe a hic-up when you tried it earlier?
Reply #7January 14, 2009, 05:05:49 am
CorsaCruiser
  • 5
    • My stuff
Diesel Tach
« Reply #7 on: January 14, 2009, 05:05:49 am »
I've got a digital tachometer (from a Vauxhall Astra GTE) connected to the W terminal of my diesel (Vauxhall) Nova,
using a converter made by Dom, which can be bought on http://www.picbits.co.uk/catalog/index.php
Easy to set up (up, down and set button) and cheap enough (for the lazy ones like me).
http://www.youtube.com/watch?v=-WkOW9B8qOg
Reply #8January 14, 2009, 06:00:48 am
arb
Diesel Tach
« Reply #8 on: January 14, 2009, 06:00:48 am »
Quote from: "libbybapa"
I assume y'all read the end of the FAQ Gas tach conversion where jimbote describes how to add a Ford probe to the crank along with part #.  No rewiring required.  Cheaper than the optical sensor that Roger Brown uses.
Andrew
Hi Andrew. I read that too, but at first I could not see where is shows how to wire the Ford Hall Sensor...  Then I read the entire thread and saw it is so simple it did not need a diagram :-)  I searched the web and found one reference to the cost being less than $10 for this part !
Reply #9January 14, 2009, 09:25:22 am
TedV
  • 182
Diesel Tach
« Reply #9 on: January 14, 2009, 09:25:22 am »
if I would have known about the Ford part over a year ago when I did mine, I would have gone that route.
Reply #10January 14, 2009, 10:04:12 am
somepunk22
  • 79
Diesel Tach
« Reply #10 on: January 14, 2009, 10:04:12 am »
Quote from: "CorsaCruiser"
That looks perfect! Converter is a little expensive. Anyone else done this?
Reply #11January 14, 2009, 09:17:50 pm
Rabbit TD
  • 840
Diesel Tach
« Reply #11 on: January 14, 2009, 09:17:50 pm »
Andrew
I just read about the [jimbote] gas to diesel tach conversion and that looks by far the cheapest and least complicated method yet. Just one question, it will work with most aftermarket tachs won't it :?: This really looks like the way to go so I might as well weld those 2 nuts on the pulley now while the engine is out and look for a low rpm tach.  I guess the in- dash tachs for the Rabbits are petty high arent they, and then you're not sure they work till you get them.  I just hope it will work with a small VDO, Sunpro or something in that range for he T/D Rabbit.
Reply #12March 20, 2009, 11:44:10 am
rabbit GTI/GTD
  • 58
Diesel Tach
« Reply #12 on: March 20, 2009, 11:44:10 am »
http://store.summitracing.com/partdetail.asp?autofilter=1&part=ATM%2D3788&N=700+400442+4294925228+4294815748+4294905527+115&autoview=sku
unless your going for a stock look, i have this in my caddy, looks good, works good to, unless u wanna rev over 5 grand, they have 2 others, one gos a little higher, but not cheap
Reply #13March 23, 2009, 06:42:45 am
regcheeseman
  • 714
Diesel Tach
« Reply #13 on: March 23, 2009, 06:42:45 am »
Video of standard set up
Gasser unit modified as per the FAQ on here.
£20 and a gasser revcounter gets you the same.[/url]
