Author Topic: 1.9aaz & 1.6Td sell-off: Everything must go!!  (Read 22832 times)
January 05, 2009, 06:04:45 am
addautomotive
« on: January 05, 2009, 06:04:45 am »
My current fleet is all non-VW, so I've decided to sell off my ridiculous stockpile of VW diesel stuff. Yesterday I tore down 3 (count 'em, THREE) 1.9AAZs, and one VW 1.6.
All the 1.9s were from cars I had driven home to pull the engines. The 1.9aaz with 167k kms was a SWEET engine I was saving for myself, but now I don't need it.  The 1.6 was a longblock someone gave me.
I'll get some pictures tomorrow, but here's what I'll list so far
Injection pumps
1.9aaz (380k kms) $120 (no sprocket)
1.9aaz (240k kms) $200 SOLD locally
1.9aaz (167k kms) $250
1.6td (core) $75
Turbos
k14 (380k kms) $75 (some shaft play, minus oil return line)
k14 (240k kms) $150 (including oil return line)
1.9aaz engine heads(with cam, valve cover, cam sprocket)
(380k kms) $75 - has cracks going to precups, *no valve cover*
(240k kms) $200 SOLD! Faulknern
(167k kms) $250 SOLD! blkboostedtruck
1.6 heads
TD mechanical lifter head (core: never heard running) $50
TD hydraulic head (core: never heard running) $50
1.6 n/a mechanical lifter head (core: never heard running) $50
Injectors
1.6 (core) $40 TWO SETS
   1 sold: cyrus #1
1.9aaz (380k kms) $80
1.9aaz (240k kms)
1.9aaz (167k kms) $125 SOLD! blkboostedtruck
Assorted:
- 020 0.71 5th gear cluster $120 SOLD Kudagra
-AAZ Intake manifolds (THREE) $60
            ONE: cyrus #1
            ONE:Powered by Spearco
-K14/K24/T2/T3 Exhaust manifolds (THREE) $40
-AAZ Injector lines (TWO sets) $50
            ONE: blkboostedtruck
-AAZ windage trays (THREE) $25
-AAZ Serpentine tensioner assemblies (TWO) $80
            two assemblies: blkboostedtruck
-AAZ cluster with working tack & speedo, ~ 200k kms $80
-AAZ 70A alternator $60
-AAZ Water pump & thermostat assembly & housing (two) $50
-AAZ Oil filter flange with oil cooler & coolant lines (three) $75
-AAZ 1.9 crank machined for AHU pulley $200
-AAZ 1.9 cranks - NEED nose machined (two): $50
-AAZ oil pumps (three) $50 each
-AAZ glow plug "bus bar" $20
-Frost plug block heater $20
-MK1 passenger side engine mount $30
-1.6 n/a injector lines $40
-1.6 vacuum pump $20
New parts, still in box:
-Timing Belt: $25 SOLD locally
-Timing belt tensioner: $25
-Rear crank seal w/aluminum housing: $30
Also sold by special request:
AAZ Oilpan: stewardc
AAZ Vacuum pump: blkboostedtruck
Aside from the stuff listed, I have BOXES of bits and pieces. Brackets, tubes, pulleys, mounts... If there is ANYTHING you're looking for, ask here or shoot a PM.
ALL of this stuff has to go, PRONTO... I need room. All prices USD, if the prices seem out of whack fire me a PM. I am open to offers.
Will take pics tomorrow or wednesday
Reply #1January 05, 2009, 06:30:42 am
Jettage1
  • 202
    Past VWs: 80 Scirocco S, 90 GTI, 00 Passat GLX
« Reply #1 on: January 05, 2009, 06:30:42 am »
How about a lower timing belt plastic cover for the 1.6?
Steve
92 Jetta EcoDiesel
     pumped by Giles...powered by Frybrid...functional by dumb luck
Reply #2January 05, 2009, 06:34:37 am
addautomotive
« Reply #2 on: January 05, 2009, 06:34:37 am »
Quote from: "Jettage1"
I'll check to see what I have!
Reply #3January 05, 2009, 08:17:22 am
53 willys
« Reply #3 on: January 05, 2009, 08:17:22 am »
how much would shipping be for the K14 to 84043???
thanks
Reply #4January 05, 2009, 09:37:37 am
CODE4LS1
  • 73
« Reply #4 on: January 05, 2009, 09:37:37 am »
Do you happen to have a turbo intake tube for a 1.6?  Goes from the airbox to the turbo.  Thanks!
Reply #5January 05, 2009, 09:52:24 am
addautomotive
« Reply #5 on: January 05, 2009, 09:52:24 am »
Quote from: "53 willys"
thanks
7 day shipping would be ~$46
24 day shipping (usually only takes 2 weeks) ~$30
Quote from: "CODE4LS1"
Sorry, I have several 1.9 ones but no 1.6.
Reply #6January 05, 2009, 10:08:26 am
stewardc
« Reply #6 on: January 05, 2009, 10:08:26 am »
Would you have an oil pan for an AAZ ?
Reply #7January 05, 2009, 10:09:59 am
addautomotive
« Reply #7 on: January 05, 2009, 10:09:59 am »
Quote from: "stewardc"
I have 4! $20, add $25 if you want the windage tray too.
But you offered to help me out with that trailer in NS last year... so I just PM'd you a "special" price.
Reply #8January 05, 2009, 11:00:07 am
blkboostedtruck
  • 1535
« Reply #8 on: January 05, 2009, 11:00:07 am »
Hi Jake,
i'm interested in the 167km AAZ head
and 2 serp accessory brackets i do need the double ended bolts with them too!
also i need a couple 1.9 vac. pumps
whats my price for all this?
i also need a oil return for a K14 can you part with one or do i need to buy the whole crapper turbo?
and shipping to milwaukee, Wi. 53221
well get back to me i'm a big spender! ask Tyler (burn your money)
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #9January 05, 2009, 11:25:37 am
addautomotive
« Reply #9 on: January 05, 2009, 11:25:37 am »
Duane, PM sent!
Reply #10January 05, 2009, 12:37:04 pm
« Reply #10 on: January 05, 2009, 12:37:04 pm »
Quote from: "addautomotive"
thanks
Can we get a deal if we buy both the k14's?
Shipping would be to the same location as in 53 willys and I both live in the same area.
Reply #11January 05, 2009, 12:43:21 pm
addautomotive
« Reply #11 on: January 05, 2009, 12:43:21 pm »
Hey, I also have a Brand-Spanking-New Samurai clutch, still in the box. Paid $160, will take $120
I'd sell the two k14s for $200+ shipping, because now one is missing the oil return tube. You guys would have to decide who gets the one with shaft play and no return tube, and who it gets shipped to.
I think $200 for two k14s is a pretty good deal!
You know what's funny is that Somewhere In The Garage I have a beautiful K24, but I'll be damned if I can find it. Ah well, maybe I'll save it for my Toyota 2.4
No action on the 1.9 IPs??
Reply #12January 05, 2009, 04:05:53 pm
thedeezel1
  • 11
parts for sale
« Reply #12 on: January 05, 2009, 04:05:53 pm »
I am interested in the 240k 1.9 head, also the injectors form the same engine.
I also need an intake and exhaust manifold, and injector lines.
I would also be it the market for the oil lines for the turbo.
Let me know what the total would be for everything shipped to 50161.
Thanks
Reply #13January 05, 2009, 04:09:00 pm
thedeezel1
  • 11
« Reply #13 on: January 05, 2009, 04:09:00 pm »
I would also be interested in the $250 1.9 injection pump, was it leaking at all before it was removed from the engine?
Reply #14January 05, 2009, 05:39:04 pm
addautomotive
« Reply #14 on: January 05, 2009, 05:39:04 pm »
Quote from: "zukgod1"
Shipping the two turbos to utah would be $50.75. Lemme know as I have a second offer on them, but you answered first.
