VWDiesel Blog
Facebook Group
VWD on Twitter
injection pump question
Topic: injection pump question (Read 1873 times)
December 28, 2008, 03:14:22 pm
96jetta
December 28, 2008, 03:14:22 pm »
i spun my pump still on the motor and attached to fuel but there was no fuel being spit out from the line. is this normal does it need the back pressure from the motor or is there a guasket leaking?
December 28, 2008, 04:19:29 pm
December 28, 2008, 04:19:29 pm »
I assume this is your user name jetta?
Try turning the key on so the stop solenoid is open.
I don't know what back pressure from the motor or a leaky gasket has to do with it.
December 28, 2008, 05:31:52 pm
Op-Ivy
December 28, 2008, 05:31:52 pm »
The solenoid on the distribution part of the pump needs 12 volts in order to let fuel out. Fual will NOT come out unless this solenoid is open.
Even with the solenoid open, cranking it by hand, you won't see much fuel come out.
When I had the lines off and tried cranking it over, the pump was barely squirting out any fuel.
1990 TD Jetta - 490,000Km
December 28, 2008, 05:35:21 pm
December 28, 2008, 05:35:21 pm »
If you turn the key on and hold the fuel lever all the way to full the fuel should come out faster.
December 28, 2008, 10:24:32 pm
96jetta
December 28, 2008, 10:24:32 pm »
ya i relised that after
. thanks for the help though
December 28, 2008, 10:59:02 pm
Rabbit TD
December 28, 2008, 10:59:02 pm »
I did the same thing once, makes you feel like an ass don't it? :lol: I feel that way a lot now days :lol:
December 29, 2008, 01:51:52 pm
96jetta
December 29, 2008, 01:51:52 pm »
ya lol i does it quite well. i seem to be doing the same haha :p
