Author Topic: T3 vs K24  (Read 9191 times)
December 22, 2008, 09:10:37 am
greatpenguin
  • 38
T3 vs K24
« on: December 22, 2008, 09:10:37 am »
Oh, im sure this has been discussed tons here, but i cant seem to find anything on the subject.  Im sitting on a T3 and a K24 turbo for my rebuild, But i have to sell one to get some money back.  From what I can see the K24 seems to have better flow potential, but looks a tad smaller.  The T3 looks a tad bigger, and better made, but looks like its restrictive which may remove any advantages.  Im looked to squeeze out every last drop of power.  Any help on the subject would be appreciated.
81 Vw Caddy 1.6l TD Project
01 Vw Jetta 20v gasser
Reply #1December 22, 2008, 09:15:10 am
53 willys
T3 vs K24
« Reply #1 on: December 22, 2008, 09:15:10 am »
if you want ALL the power you can get sale the t3 and get a K26 and make a K24/K26 hybrid..... :lol:  8)
Reply #2December 22, 2008, 09:28:11 am
greatpenguin
  • 38
T3 vs K24
« Reply #2 on: December 22, 2008, 09:28:11 am »
exhaust of the 24 intake of the k26?  There is a used k26 on ebay for $86, This could be a doable idea.
Reply #3December 22, 2008, 09:34:45 am
T3 vs K24
« Reply #3 on: December 22, 2008, 09:34:45 am »
The 26 cold side bolts right up to the 24 center section.
Both 53 willys and i are running one as are a few other members.
Reply #4December 22, 2008, 09:39:20 am
greatpenguin
  • 38
T3 vs K24
« Reply #4 on: December 22, 2008, 09:39:20 am »
how much more power does this give?  The only thing I am not sure of is since the 24 has the built on wastegate and the k26 does not, there is some plumbing to take in account for (I dont have my turbo's on me currently).  Is that not an issue?
Reply #5December 22, 2008, 09:52:39 am
TurboJ
  • 661
T3 vs K24
« Reply #5 on: December 22, 2008, 09:52:39 am »
Sell the T3 in any case. The impeller diameters are exactly the same on the T3 and the KKK24, while the KKK is overall a much better turbo. It's more efficient (slightly) and still has better spool-up. A hybrid KKK would be nice if you can't get your hands on a suitable Holset or Schwitzer.
Jetta II 1.6 TD 'Project 200'
Reply #6December 22, 2008, 09:55:10 am
TurboJ
  • 661
T3 vs K24
« Reply #6 on: December 22, 2008, 09:55:10 am »
Quote from: "greatpenguin"
The wastegate is not a problem, just use the KKK 24 turbine with the original W/G . As for power, it will greatly depend on what kind of KKK26 cold side you use (there are dozens of different sizes and specs), but a stock KKK24 has been proven to make over 160 hp in ideal conditions. So it's gonna be able to do better than that!
Reply #7December 22, 2008, 10:07:00 am
greatpenguin
  • 38
T3 vs K24
« Reply #7 on: December 22, 2008, 10:07:00 am »
This is the one on ebay (if someone else nabs it i will be sad).  This sounds like the way to go then.  I was just worried about the hose from the cold side that runs to the wastegate, as this one does not have that.  I suppose its nothing that a turbo shop couldn't do for me anyways.  If I was to get a rebuild kit... Would I have to grab both then?  The add says this is off of a porche 944
Reply #8December 22, 2008, 10:11:36 am
TurboJ
  • 661
T3 vs K24
« Reply #8 on: December 22, 2008, 10:11:36 am »
No, you would only need the KKK24 service kit, unless you were to use a KKK26 center section.
A KKK26 out of a 944 supports about 270 hp on a gas engine, so that should mean something in the region of 200 hp on a diesel engine.
Maybe the hybrid would have a max output of around 180 hp? You never know until you've tried it, but maybe it'll be in that ballbark.
Reply #9December 22, 2008, 10:13:27 am
53 willys
T3 vs K24
« Reply #9 on: December 22, 2008, 10:13:27 am »
I got my k26 at a local junkyard for $60..then I paid $100 for a rebuild kit...then I paid $80 to have the k24 housing machined to fit the K26 exhaust wheel...
i'm pretty happy with it...although I dont have much time on it yet..
Reply #10December 22, 2008, 10:18:11 am
greatpenguin
  • 38
T3 vs K24
« Reply #10 on: December 22, 2008, 10:18:11 am »
Quote from: "53 willys"
So, in order to match them up, it does require machining of the k24 housing?  I dont know of a local place i trust that does that.
Reply #11December 22, 2008, 10:21:28 am
TurboJ
  • 661
T3 vs K24
« Reply #11 on: December 22, 2008, 10:21:28 am »
No. That's only if you want to use a KKK26 hot side.
If you use a 24 hot and center section, you'll have your hybrid by just bolting on a KKK26 cold side.
The 26 that you mentioned, BTW, would suit this quite well as it's not the bigger '89-'91 944 Turbo's, but the earlier, smaller one (!)
Reply #12December 22, 2008, 10:37:59 am
greatpenguin
  • 38
T3 vs K24
« Reply #12 on: December 22, 2008, 10:37:59 am »
Well, I bought the K26.  Guess that answers my first question, and cost me more money :)
Now I need to sell my spare TD kit.
Thanks for the quick input guys!
I should just move my build thread over here, i'll get alot more imput from you guys.
Reply #13December 22, 2008, 11:20:47 am
rallydiesel
  • 1880
T3 vs K24
« Reply #13 on: December 22, 2008, 11:20:47 am »
Sounds like you'll have a very nice turbo set-up on your hands!
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #14December 22, 2008, 02:50:05 pm
dillenger1
  • 777
T3 vs K24
« Reply #14 on: December 22, 2008, 02:50:05 pm »
Quote from: "TurboJ"
where do you get your information?I feel the t3 is way more robust.
1.6td in toyota pickup
10mm head ,t3 intercooled.
