Author Topic: free power on a stock aaz  (Read 16375 times)
Reply #45January 24, 2009, 02:37:28 pm
rov716y
  • 96
« Reply #45 on: January 24, 2009, 02:37:28 pm »
Quote from: "Tony2ltr"
is the stock downpipe really that restrictive?
-Tony
it is if its a 1.6n/a on a 1.9td!!
Reply #46January 24, 2009, 06:23:43 pm
Tony2ltr
  • 53
« Reply #46 on: January 24, 2009, 06:23:43 pm »
I am only talking about the 4 bolt flanged, cast iron piece with the 90 degree bend coming to the front pipe from the turbo/wastegate housing with the graphite ring seal, is this a very restrictive piece?
  The rest is all something that can be easlily modified. I made a 2.5 inch front pipe using the stock funnel flange. I have a straight pipe all the way back, and can hear the turbo spinning in the exhaust when it is sitting there idling (pretty cool). I wondered about that cast downpipe though.
-Tony
92 Jetta Ecodzl/biodzl/WVO/meth-H2O turbspray
1969 Subaru 360 Sambar (converted to Electric)
1975 Chevy Cosworth Vega Turboed
1991 Toyota Pickup (megasquirted)
2004 POS Honda Civic (I'll never buy another)
2 cylinder Lister Petter diesel CO-Gen unit
Reply #47January 24, 2009, 07:10:19 pm
  • 3468
    • McScrubbins Body Wash
« Reply #47 on: January 24, 2009, 07:10:19 pm »
yes! Look at the difference between three inch downpipes and the stock one. It's highest restrictive point is probably only 1.5inch in diam. It's brutal.
Reply #48January 25, 2009, 08:19:06 am
Tony2ltr
  • 53
« Reply #48 on: January 25, 2009, 08:19:06 am »
I thought it might be a bit bigger... I never really looked at it really well. I have one more 90 degree stainless elbow from the 3" system on the vega.  I will have to look at replacing this awful offender of free flow then!
-Tony
Reply #49January 25, 2009, 10:29:50 am
dillenger1
  • 777
« Reply #49 on: January 25, 2009, 10:29:50 am »
the hardest part is the square manifold to pipe weld.Its hard to be able to keep clearance for the nuts.I had trouble with 2 1/2".
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #50January 25, 2009, 05:10:49 pm
Tony2ltr
  • 53
« Reply #50 on: January 25, 2009, 05:10:49 pm »
I had the same trouble on the vega. It is not bad at all for flow to use a short 1-1/2 or 2 to 3 inch adapter that gives you room for the nuts, or heat it up with a flamewrench after to hammer in the nut areas for clearance.  Using a different fastener to gain tool clearance can give you some options too I would imagine. If you read old turbo books, the best way to do this kind of thing is to use a large toroid shaped expansion chamber with your down pipe at some tangent. It helps to shape the flow of the turbulent gasses out of the turbo.
-Tony
