Author Topic: head gasket - leaking again 1.6TD  (Read 11784 times)
Reply #15December 22, 2008, 03:43:22 am
  • 3468
    • McScrubbins Body Wash
« Reply #15 on: December 22, 2008, 03:43:22 am »
not a vanagon owner here but your turbo could have worn through on the shaft. Could be looking at a rebuild :( ?
with torque to yield stretch bolts, the torque sequence could have come with the head gasket?
My bentley says
Torque the bolts to 40 Nm (30 ft. lb.), in the sequence shown in the pic i posted there above. Repeat the sequence, torquing the bolts to 60 Nm (44 ft. lb.). Repeat the sequence a third time, tightening each bolt an additional 1/2 turn. Alternatively, this last step may be done as two 1/4 turns.
Run the engine until it reaches normal operating temperature. Retorque the cylinder head bolts in sequence 1/4 turn without loosening. For engine codes ME and MF only, after appx. 1000 miles, retorque the cylinder head bolts an additional 1/4 turn, without loosening and without "interruption" - so very smoothly and fluidly.
Reply #16December 22, 2008, 07:01:30 am
joe1975
  • 12
« Reply #16 on: December 22, 2008, 07:01:30 am »
Thanks for the advice.  I took the turbo off today and called ITS who i bought it from and they told me to send it back so they could check it over.
As for the water leak i used some plumbers type gasket on it.  We will see when i get it going in the new yr.
For now, its all stop for Xmas as the Turbo won´t be back until the new year.
Thanks to everyone who helped.
Merry Christmas ... :D
1.6TD Syncro Vanagon - UK
