Author Topic: turn signals  (Read 4707 times)
December 09, 2008, 05:34:49 pm
  • 3468
    • McScrubbins Body Wash
turn signals
« on: December 09, 2008, 05:34:49 pm »
I had to get different light mounts to use big bumpers on my '90 and the left turn signal flashes very quickly now.
I always associated this with a bulb near it's death so i changed it and it still does it...
¿Pour Que?
Reply #1December 10, 2008, 12:14:20 am
79rabbit4dr
turn signals
« Reply #1 on: December 10, 2008, 12:14:20 am »
(Prior to today)
same question, my drivers side flashes quickly but my pass side seems normal.
(Tonight)
neither of them worked, but it was wicked cold and it'd been sitting for a couple days.
Reply #2December 10, 2008, 02:45:29 am
turn signals
« Reply #2 on: December 10, 2008, 02:45:29 am »
my left side did that a few nights ago.. it's working fine now.  but its warmer now than it was then... i'd associate it with just a bad connection.  maybe clean up the contacts.  i just spotted a missing piece in my turn signal lense so water could get in that way and mess everything up.
Reply #3December 10, 2008, 07:58:46 am
  • 1739
turn signals
« Reply #3 on: December 10, 2008, 07:58:46 am »
turn signal flashing too fast = i bulb is inop. Clean the contacts, bend the terminals so they touch tighter, use some di-electric paste to improve the connection.
Reply #4December 10, 2008, 11:00:46 am
AndrewSE
turn signals
« Reply #4 on: December 10, 2008, 11:00:46 am »
Have the same problem for my passenger side.
I have a bad connection that needs resoldering on mine.
Half of the outside wiring is starting to crumble due to that great winters we have here in T.O
Reply #5December 10, 2008, 05:39:41 pm
  • 3468
turn signals
« Reply #5 on: December 10, 2008, 05:39:41 pm »
Hmmm. I did all the connections up front. Maybe its a problem in the rear lights. I just associated the issue with me changing the bumpers.
Reply #6December 11, 2008, 03:20:07 am
clbanman
  • 705
    Cambridge, Ontario
turn signals
« Reply #6 on: December 11, 2008, 03:20:07 am »
Did you mess up a ground?  Try clipping a jumper from the battery negative to the light sockets on the bumper you replaced.
Calvin
91 VW Golf 1.6NA 5spd
Reply #7December 11, 2008, 05:20:28 am
DCC
  • 184
turn signals
« Reply #7 on: December 11, 2008, 05:20:28 am »
Quote from: "Smokey Eddy"
The rear lamps are prone to fail from time to time. I usually give it a shot of contact cleaner (CRC) and it's fixed.  :)
Reply #8December 11, 2008, 07:06:56 am
  • 3468
turn signals
« Reply #8 on: December 11, 2008, 07:06:56 am »
Quote from: "clbanman"
They are plastic?
Reply #9December 11, 2008, 07:07:11 am
  • 3468
turn signals
« Reply #9 on: December 11, 2008, 07:07:11 am »
Quote from: "DCC"
ok!
