General Information
Troubleshooting
lack of power TDI
Topic: lack of power TDI (Read 6702 times)
July 13, 2005, 09:32:12 pm
joemob
Newbie
lack of power TDI
July 13, 2005, 09:32:12 pm »
my 2000 jetta tdi, is lacking power on acceleration past 3000rpm, we cleaned the intake,egr,changed the air filter, and cleaned all visible carbon residue, but some how still lacks power, any help or tips?
July 13, 2005, 11:16:10 pm
asau
lack of power TDI
July 13, 2005, 11:16:10 pm »
unplug your maf, any difference? if so the your maf needs to be replaced. another maf test is to rev the car while in nutral do the rpm's stop at the redline or below? if the rpms stop below redline then maf needs replacing
July 14, 2005, 01:52:10 pm
joemob
Newbie
lack of power TDI
July 14, 2005, 01:52:10 pm »
i have disconnected the maf sensor, but did not affect anything, also reved engine in neutral, and it goes to redline, could this be a turbo, or Fuel filter problem?
July 14, 2005, 11:13:48 pm
asau
lack of power TDI
July 14, 2005, 11:13:48 pm »
try removing the snow screen, and changing the air filter
July 15, 2005, 02:58:25 pm
joemob
Newbie
lack of power TDI
July 15, 2005, 02:58:25 pm »
still the same..... Dr.DIESEL have anything to say???
July 15, 2005, 11:41:09 pm
asau
lack of power TDI
July 15, 2005, 11:41:09 pm »
i am 99% sure your maf needs to be replaced, look in you bentley and follow the procedure for testing the maf sensor
July 27, 2005, 07:49:21 am
joemob
Newbie
lack of power TDI
July 27, 2005, 07:49:21 am »
new MAF just installed and its still f*%&ed
July 27, 2005, 09:01:25 am
Maarten
lack of power TDI
July 27, 2005, 09:01:25 am »
Does the rpm go over 3000 rpm when you drive or do you hit a rpm limiter here? if so, get your ECU checked for faultcodes.
Did you check the airfilter (check the box and piping too for birds/rats etc clogging the intake) and dieselfilter? With the engine running unscrew the bolt on top of the injector a LITTLE bit to see if every injector gets fuel.
Get in contact with someone who has a VAG tester or VAGCOM and check the measurementblocks for strange values.
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
July 27, 2005, 08:37:29 pm
joemob
Newbie
lack of power TDI
July 27, 2005, 08:37:29 pm »
in neutral it redlines, in first gear it gets up to 4000 rpm, in second it gets up to 3000/3200 rpm, in third it maybe goes to 2500 rpm and slowly increase. intake is free, new MAF, cleaned egr. someone told me to get the intake cleaned right down to the valves?
July 28, 2005, 12:48:21 am
Maarten
lack of power TDI
July 28, 2005, 12:48:21 am »
The intake could be clogged up with chucks of the evil black stuff when you cleaned the EGR.. take off the manifold and clean it, it doesn't hurt to do that anyway.
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
General Information
Troubleshooting
lack of power TDI
