Author Topic: FS: 94 Jetta GL TD 3000 obo NEED IT GONE  (Read 3733 times)
December 03, 2008, 01:57:56 pm
beew
  • 27
« on: December 03, 2008, 01:57:56 pm »
Putting my 94 Jetta GL up for sale
I bought this car at the beginning of August from Foster Auto in Waterdown, ON with 374k km on it. It was certified in Sept.
fully loaded
however, AC, heated seats, cruise (needs a computer), drivers side window (i have a replacement motor) do not work
approx 380k km
engine has been updated to a TDI crank so the crank wobble is not an issue
tons of new parts
balljoints, outer tie rod ends, cv joints, front pads and rotors, rear struts and an alignment done at 374km
new injection pump (throttle shaft was worn and caused shaft to leak on the old one), timing belt/tensioner,(timing set by Schnells VW in Peterborough) engine oil+filter, fuel filter done at 376km
also has a new battery, wiper motor, wipers, glow plugs
summer tires (2 not so good) on rims and snow tires (nordic icetracs) on rims which are currently on it
as is and etested, should not be a problem to certify as it was done 6000km ago
$3000 obo or trade? i have put that into it in parts alone since i bought it
This car is my daily driver and would like a 4x4 truck. Car is currently in Lindsay, ON until Dec 11 when ill be done school and the car will be in Orillia after that.
94 Jetta GL diesel
Reply #1December 08, 2008, 11:41:34 am
beew
  • 27
« Reply #1 on: December 08, 2008, 11:41:34 am »
ttt..need it gone
94 Jetta GL diesel
