Author Topic: Found a sick spot for guages! mk2  (Read 8653 times)
Reply #15January 02, 2009, 10:44:28 am
  • 3468
    • McScrubbins Body Wash
« Reply #15 on: January 02, 2009, 10:44:28 am »
Quote from: "88jetta350"
Not to Pi** on your project, but why did you use different gauges? IMO it would have turned out better if you used all the same kind of gauges.
BTW, it's a cool idea. I like it, and have considered this myself, now that i've seen it done, I just might do it.
Because I don't have a lot of money to spend on projects. I need a car to go to school and for a bit of extra cash i can monitor the engine so hopefully it will last longer (or i can catch problems before i break things i cant afford to break)
All four gauges cost me .... maybe 110$ cdn? that includes the EGT.
matching gauges would have raped my wallet quite severely.
ps. I'd love to see matching oil pressure, boost, egt and tach gauges. Please, post a picture. (maybe something other than VDO too?)
Reply #16January 03, 2009, 03:27:10 am
88jetta350
« Reply #16 on: January 03, 2009, 03:27:10 am »
Ahh, budget contraints. Believe me, i understand.
If I had the money to do what I want to my car, I would have one of the fastest IDI MKII's in Germany. :)
Also, I know how much gauges can run, if you found a good deal on them, then good for you. :)
Hopefully you opted for "inexpensive" rather than "cheap" because cheap gauges can sometimes be just as bad as none at all. :(
Reply #17January 03, 2009, 03:29:13 am
  • 3468
« Reply #17 on: January 03, 2009, 03:29:13 am »
well i'll see soon! Going to be ready to start soon!
Reply #18January 22, 2009, 06:22:19 am
spencebm
  • 686
« Reply #18 on: January 22, 2009, 06:22:19 am »
where did you get your pyrometer from ed?  I was thinking about placing gauges where the air vents are on the drivers side/center to make them look oem.
Ben Spencer
Reply #19January 22, 2009, 10:49:50 am
  • 3468
« Reply #19 on: January 22, 2009, 10:49:50 am »
by pyrometer is that another name for exhaust gas?
I bought all my gauges, less the tach, from prothe's site.
realized i had a picture taken with a better camera, here it is. It was to show the oil temp so thats why i don't have one of the other two. I will in the next month though!
Reply #20January 26, 2009, 04:40:34 pm
ein bora
  • 377
« Reply #20 on: January 26, 2009, 04:40:34 pm »
Someone mentioned the angle things, autometer makes a proper bezel for just that.
I have a set on my other car, makes for a nice clean looking installation.  Their part number #2234 and run about $10.00 from Summit Racing. Maybe cheaper elsewhere??
http://store.summitracing.com/partdetail.asp?autofilter=1&part=ATM%2D2234&N=700+115&autoview=sku
Looks good - good luck with it!
If you can't take advice - then you can't be helped!
