Author Topic: head crack of doom ??!!  (Read 5951 times)
November 29, 2008, 09:54:42 pm
« on: November 29, 2008, 09:54:42 pm »
Busy rebuilding another AAZ as a winter project... doing the teardown and so far so good... until this crack to the prechamber:
The wet stuff is just brake drum cleaner.  The head is in really good shape otherwise...very straight with great guides and lifter bores.
We know that small cracks between the valves are normal... and in comparison the crack to the prechamber doesn't seem worse... but... :?:
I'd interested to hear some experienced opinions on the viability of re-use... AAZ heads don't grow on trees, but I'm not one to knowingly park my family by the side of the road.
Reply #1November 29, 2008, 10:09:25 pm
« Reply #1 on: November 29, 2008, 10:09:25 pm »
i wonder how far that crack goes???  :shock:
did you pull the head from a known good running motor??? i'd say that its on its last legs for sure.  you could nearly cough on it and it would have a leak.
Reply #2November 30, 2008, 12:21:37 am
  • 3468
    • McScrubbins Body Wash
« Reply #2 on: November 30, 2008, 12:21:37 am »
:cry: *sniff*
Reply #3November 30, 2008, 06:48:24 am
handedyourhat
  • 33
cracker
« Reply #3 on: November 30, 2008, 06:48:24 am »
anyone ever put one of these heads in a bandsaw and cut it in half to see how thick the area is where the cracks are ?
Most of the time I get sooo far ahead of myself that I have to stop and let myself catch up......
87 jetta 1.6L TD project
87 jetta 1.6L TD Daily  (new 1.6, Giles,3", inner cooled. Home made fuel...
95 jetta 1.9L TD project
94 golf TD new edition to my family (LOL)
Reply #4November 30, 2008, 07:17:04 am
Re: cracker
« Reply #4 on: November 30, 2008, 07:17:04 am »
Quote from: "handedyourhat"
Aha !!  That's *exactly* the question I meant to ask !!  If the metal is the same thickness in that region, and cracks between valves are known to be fine... this one should be fine as well.  But it all depends on the profile of the metal behind the crack.
'Twould be an interesting bandsaw experiment for sure.
Reply #5November 30, 2008, 08:28:58 am
saurkraut
  • 904
« Reply #5 on: November 30, 2008, 08:28:58 am »
In my experience, cracks emanating from the swirl chamber are always fatal.
I've had them slow leak, and give you some time to get it home, and some that go big-time; take the burp bottle cap off and idle it home.
There are some photos on this forum in a post about IDI Improvements from the early days of this forum with some cross sections done by RedRotors.
Link to RedRotors' orginal post: IDI engine, there IS a future...
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #6November 30, 2008, 11:45:00 am
« Reply #6 on: November 30, 2008, 11:45:00 am »
Great cross-sections... thanks for posting !!
Reply #7December 01, 2008, 03:11:00 am
dillenger1
  • 777
« Reply #7 on: December 01, 2008, 03:11:00 am »
The area in question definetly looks meaty enough,but lookj how far the valve crack goes in.I never thought it was like that!
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #8December 01, 2008, 08:24:42 am
dieselweasel
  • 312
« Reply #8 on: December 01, 2008, 08:24:42 am »
I don't have any wisdom from experience to share, but I don't think I'd reuse that head Vince.  You could have it pressure tested and it would likely be ok but the crack may get deeper over time and extend into the cooling system.  Also I have heard of pre-cups coming loose and falling into the cyliner...that crack may increase the chances of this?
Reply #9December 01, 2008, 08:25:44 am
« Reply #9 on: December 01, 2008, 08:25:44 am »
If you had the time and the equipment I would think one could repair it. Knock out the precup and race of the offending port then get a small bit for your die grinder and notch it out. Tig it up and have it machined flat. New valve seat and off to the races.
