Author Topic: Runs rough, surges...aaargh!  (Read 4742 times)
Reply #15November 29, 2008, 11:49:12 am
smutts
  • 720
    ClackClackClackClackClack
« Reply #15 on: November 29, 2008, 11:49:12 am »
Uber Bodge coming up. Perhaps one of the cones out of a bicycle axle with a suitable bolt might do? :?
Reply #16November 30, 2008, 09:34:00 am
« Reply #16 on: November 30, 2008, 09:34:00 am »
Quote from: "dillenger1"
Are we talking about the bottom bolt on the injection pump support/because ive run with that bolt completely out (for adjustment)If the other three mounting plate bolts are tight,that thing wont go anywhere!
I THOUGHT it was fine - you couldn't really see the pump moving or anything, but at certain RPM ranges the pump would get a harmonic going on and start to dance.  The more advanced my timing was the easier it was to trigger the surging behavior, but with the timing retarded a bit the car was perfectly drivable.  But like I said, once I dealt with that bolt I couldn't believe the difference!
Reply #17December 15, 2008, 11:43:14 am
fastvicar
  • 154
« Reply #17 on: December 15, 2008, 11:43:14 am »
Steve, I've been following your thread & was perplexed by this surging you were experiencing.  Then, last Friday, mine started to do the same thing.  I checked the IP bolts & all were snug.  It still surged.  Today I decided to take a peak in the the light of day.  Sure enough, two of the IP bracket bolts were backed off & the pump would get into a visible harmonic pattern.  I snugged the bolts back up as best I could & it seems to be better.  Any recommendations on tools that can reach those two bolts with the IP still in place?
1981 Rabbit 1.6L TURBO!!  "The Whistle Pig"
Reply #18December 15, 2008, 12:54:31 pm
  • 3468
    • McScrubbins Body Wash
« Reply #18 on: December 15, 2008, 12:54:31 pm »
socket and extension?
which are we talking about?
Reply #19December 15, 2008, 01:13:07 pm
« Reply #19 on: December 15, 2008, 01:13:07 pm »
Quote from: "fastvicar"
Are you refering to the 2 bolts behind the IP?
Reply #20December 16, 2008, 10:09:57 am
fastvicar
  • 154
« Reply #20 on: December 16, 2008, 10:09:57 am »
Two bolts that hold the IP bracket to the block, underneath the IP.  The bracket itself and the IP interfere with getting a 3/8" socket in there properly.  I got a 1/4" in there, but who trusts the torque put out by a 1/4" driver?
The good news is that it starts easier.  I'm hoping that fuel economy will be more in line with what I expect.  Who knows how long the bracket has been loose?  I do know that the IP was replaced about 3 months before I ever got the car.
Reply #21December 17, 2008, 12:35:36 pm
smutts
  • 720
« Reply #21 on: December 17, 2008, 12:35:36 pm »
Crescent or ess spanners will get you at what lurks behind the I.P.
 A must for when the water pump dies. :twisted:
Reply #22December 17, 2008, 12:36:21 pm
smutts
  • 720
« Reply #22 on: December 17, 2008, 12:36:21 pm »
Ballet dancing transvestites??????????????????? :?
Reply #23December 20, 2008, 12:44:16 pm
smutts
  • 720
« Reply #23 on: December 20, 2008, 12:44:16 pm »
You don't get the Royal Variety Performance your way then?  :lol:
