Fixmyvw.com
Author Topic: m-tdi timing  (Read 24715 times)
November 17, 2008, 08:11:52 pm
oldskool rich
  • 446
m-tdi timing
« on: November 17, 2008, 08:11:52 pm »
ive just added a disco 300tdi pump to my 1Z corrado, it seems to be ok except it doesnt like to cold start and it literaly doesnt rev from cold, i put my foot down and nothing happens untill after a few minits, when it does happen it does alot of caughing and spluttering.
I timed it to 1mm duno if thats right, but thats what you do on an AAZ, the smoke seems a little retarded though seems quite light coloured
anyone got any surgestions? it doesnt appear to be knocking so it cant be that far out, it doesnt have a manual choke so i cant control the timing with that, any ideas how i might advance it wen starting? or does it just need advancing in general?
f6squared I.D.S.T
Reply #1November 18, 2008, 04:33:20 am
Sprockets
  • 29
m-tdi timing
« Reply #1 on: November 18, 2008, 04:33:20 am »
Well, as timed in the 300TDi engine itself, it should be 1.54mm without EGR, and 1.4mm with, so I vote for advancing the pump up a bit more :)
-Gavin
Reply #2November 18, 2008, 02:01:12 pm
greg123
  • 73
    • http://www.small-engine.co.uk
m-tdi timing
« Reply #2 on: November 18, 2008, 02:01:12 pm »
Is the discovery pump a better mtdi pump than the 2.8 iveco/fiat/renault one that is banded about on here/tdi club but pretty hard to find?
Greg.
Freelance Mechanic specialising in Tdi motors and Veg-oil 2-tank conversions.
Reply #3November 18, 2008, 08:16:57 pm
oldskool rich
  • 446
m-tdi timing
« Reply #3 on: November 18, 2008, 08:16:57 pm »
thanx greg, that makes sence then
better is a strong word, disco is 11mm the 2.8 is 12mm
11mm is better for high revs, 12mm is better for low rpm
ive only experianced 11mm so far, ive heard of 12mm pps snapping at high revs and sum people swap back to 11mm so its hard to say whats better
im looking for a good mtdi pump for my 2.0 diesel, do you have any details about this 12mm pump i wouldnt mind trying it out if i can find one, i thort it was only on the AGK 2.8LT
f6squared I.D.S.T
Reply #4November 19, 2008, 04:27:03 am
greg123
  • 73
m-tdi timing
« Reply #4 on: November 19, 2008, 04:27:03 am »
As far as I know, VW never made a 2.8 litre tdi 4-cylinder.  The LT is actually a Mercedes Sprinter and should have the 2.9 5-cylinder tdi (an amazing engine) or later cdi, I guess VW wanted to source a different power train for some reason.
As far as I know, don't quote me, it's teh sofim engine.  This is Iveco's engine, as used in the Iveco Daily.  Iveco farm their Sofim engine out to the Renault Master, Fiat Ducato, Citron Relay, Peugeot Boxer and AFIK the LT 2.8.  It was popular a few years ago because few of those 'car' based mfr's had a suitable large cc engine and for the amount of vans they sell it made more sense to buy in.  Merc obviously had a range of big diesels so they were not bothered.
Even now, the new Sevel (Fiat Ducato etc) van with the 2.3 litre and 3.0 litre engines are all Sofim Iveco engines.
So, I'm thinking any of the sofim range with a mech pump and tdi (the 2nd gen 2.8, before they switched it to common rail - later went to 3.0 litre 16v with 3rd gen common rail) would do the job.
Comments? Greg.
Quote from: "oldskool rich"
Reply #5November 19, 2008, 09:48:13 am
Tintin
  • 1279
m-tdi timing
« Reply #5 on: November 19, 2008, 09:48:13 am »
Reply #6November 22, 2008, 06:12:32 am
monkey magic
  • 120
m-tdi timing
« Reply #6 on: November 22, 2008, 06:12:32 am »
rich, did you have any luck advancing the timing?
I ask because I was about to buy an aaz pump, but the disco pumps are easy to find and if they work well i'd rather use one of them..
mTDi syncro
Reply #7November 22, 2008, 07:44:47 pm
oldskool rich
  • 446
m-tdi timing
« Reply #7 on: November 22, 2008, 07:44:47 pm »
no it wont work on a an IDI, the cam plate is all wrong for the injectors
however it works great now on the TDI
f6squared I.D.S.T
Reply #8November 23, 2008, 05:36:30 am
monkey magic
  • 120
m-tdi timing
« Reply #8 on: November 23, 2008, 05:36:30 am »
Hi rich,
It's a TDi i need the pump for, so that sounds great. I'll get a landy pump and have a play.
Sadly, I just bought a 2.8 Ducato mechanical pump, and only realised when it was too late it doesn't have an LDA  :(  I will research adding an LDA, it seems possible...
Nice one rich, was it just the extra advance, or have you done anything else to the landy pump?
mTDi syncro
Reply #9November 23, 2008, 05:59:38 am
greg123
  • 73
m-tdi timing
« Reply #9 on: November 23, 2008, 05:59:38 am »
Checkout that that first, earliest, 2.8 (the non-turbo one) wasn't an IDI motor as well.  They switched to DI around then and if yours is off an IDI the profile/advance curve will be all wrong I believe.
Greg.
Quote from: "monkey magic"
Hi rich,
Reply #10November 23, 2008, 06:04:11 am
monkey magic
  • 120
m-tdi timing
« Reply #10 on: November 23, 2008, 06:04:11 am »
Greg, this pump is off a 2002, so i'm happy its a DI, just gutted it has no lda. Wonder how gutless an AHU TDi will be with no boost...
mTDi syncro
Reply #11November 23, 2008, 09:41:15 am
greg123
  • 73
m-tdi timing
« Reply #11 on: November 23, 2008, 09:41:15 am »
Very?  U should be able to fit though.  lda not di specific i think, lots about
Reply #12November 23, 2008, 09:48:49 am
greg123
  • 73
m-tdi timing
« Reply #12 on: November 23, 2008, 09:48:49 am »
Another q while I'm thinking, as the 2.8 and the disco 200tdi pumps are both di, other than the 12mm of the 2.8  is the camplate/advance curve any aything else relevant about the same?  Or is one preferable to the other?
After reading many theads it appeared the main reason not to use a idi td pump on a mtdi was the profile/advance curve.
Greg.
Reply #13November 23, 2008, 10:15:05 am
monkey magic
  • 120
m-tdi timing
« Reply #13 on: November 23, 2008, 10:15:05 am »
Not sure on the differences re landrover vs 2.8 etc. But the reason an IDI pump isn't ideal for an mTDi is the pressures generated. TDi injectors open at a much higher pressure than IDI injectors.
As a result, TDi injectors open later when driven by an IDI pump, as the opening pressure is reached later, hence extra advance being needed to compensate.
Not sure of the other differences re advance curve etc, but i'm sure there are a few..
mTDi syncro
Reply #14November 23, 2008, 12:43:40 pm
Tintin
  • 1279
m-tdi timing
« Reply #14 on: November 23, 2008, 12:43:40 pm »
The main reason is the injection time needed between IDI and DI motor.
Fixmyvw.com
