Author Topic: Junk yard gasser 1.6td swap  (Read 2039 times)
November 16, 2008, 05:19:57 pm
turbosuzi
« on: November 16, 2008, 05:19:57 pm »
I have a suzuki samurai and love the 1.6td in it. Now I am wanting to get a rabbit going. I have a td for a swap. the reason that I want to do a gasser swap from a junk yard is that in California there are not alot of diesel rabbits available, and I can buy a decent rabbit from the junk yard for $500.   Is there any thing that I should look for in a gasser by way of transmissions or other items? Is there any difference in gearing?
Reply #1November 16, 2008, 05:51:24 pm
Quantum TD
  • 1195
« Reply #1 on: November 16, 2008, 05:51:24 pm »
Obviously, try to find a car with a 5-speed trans. The gearing on all the stock Rabbit gasser 5-speeds work well with the diesel (FF, FO, FN, 7A), with the exception of a few trannies (2H, 4K, FK, & FM). The 2H and 4K were stock on the GTI and are the WORST match for a diesel. The FK and FM came on some Jettas and Rabbits and are equally horrid.
If you get the whole car with trans, it will save you from 1) buying a trans, and 2) having to swap all the components for the linkage (relay rods, shifter box, etc).
Frame rust should be top concern, but in Cali, I doubt it will be a real issue. Floor pans like to rust, as to windshield frames.
Early Rabbits (up to 1979) are lighter than the later cars, so it will improve MPG.
The gas tanks are essentially all the same. You might want to find a diesel filler tube for the larger orifice to accept the large diesel nozzles at gas stations.
You'll also have to re-route the fuel lines. The gassers finish on the driver's side of the car, the diesels finish on the pass side.
That's about it. The wiring harness would be helpful for the diesel swap. too.
Good luck!  I acutally did this a few years ago, but I had a complete diesel donor which made it easier. But it's not a really hard job. You'll want to replace all the bushings, shocks, ball-joints, CV boots, etc while you're doing the swap, as all those parts are sure to be wasted.
Reply #2November 16, 2008, 05:59:08 pm
turbosuzi
« Reply #2 on: November 16, 2008, 05:59:08 pm »
I dont think that I will need the diesel harness because I was going to run a manual gp relay. That is a good idea about the bearings and bushings. I saw alot of convertible rabbits there and I know why they didn't make any diesel convertbles but in CA it would be nice. Any reasons other than diesel fumes to not use a convertible?
Can I use a starter from a gasser?
