Author Topic: quick manifold question  (Read 4780 times)
November 14, 2008, 05:58:58 pm
monomer
  • 414
« on: November 14, 2008, 05:58:58 pm »
I've sourced a 8-valve turbo exhaust manifold, and a stock 1.6TD intake manifold.
These do infact, bolt directly to the 1.9AAZ head, correct? Some of the manifolds i've seen use a more square port (the VNT15 setup, for example)
www.michiganvw.org
Reply #1November 14, 2008, 07:12:02 pm
rallydiesel
  • 1880
« Reply #1 on: November 14, 2008, 07:12:02 pm »
The bolt spacing is the same for all the 8 valve heads. The exhaust ports are all the same shape for all the engines. The 1.6 has oval intake ports and the 1.9 (including the AAZ) have d-shaped intake ports.
You can use the 1.6TD intake manifold but you won't be making full use of the 1.9 port design. Some people have machined the manifold to match port but you have to be careful not to grind it too thin. In this case you may just want to get a gasser G60 manifold and grind it cuz it has a better runner design than the TD manifolds.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2November 14, 2008, 07:16:43 pm
monomer
  • 414
« Reply #2 on: November 14, 2008, 07:16:43 pm »
Quote from: "rallydiesel"
damn.
already ordered....
Wish I wouldve known...
www.michiganvw.org
Reply #3June 09, 2009, 06:55:44 am
stewardc
Re: quick manifold question
« Reply #3 on: June 09, 2009, 06:55:44 am »
Does the G60 manifold have D shaped ports???
Reply #4June 09, 2009, 08:23:41 am
myke_w
  • 1099
« Reply #4 on: June 09, 2009, 08:23:41 am »
negative
Reply #5April 04, 2013, 11:01:19 pm
monomer
  • 414
« Reply #5 on: April 04, 2013, 11:01:19 pm »
negative
Back from the dead.
I got an intake from what I was told was a g60 - I do believe it's an oval port.
Next question: What exhaust manifold to get for my t25 that has d-shaped ports?
www.michiganvw.org
Reply #6April 05, 2013, 09:53:07 am
wolf_walker
  • 1205
« Reply #6 on: April 05, 2013, 09:53:07 am »
I'm almost positive it's only the intake on the 1.9 that had D ports, the exhausts are all oval.
There's more than a few turbo exh manifolds for 8v vw's around, I can't help beyond that.
Mentat Text Two
Reply #7April 05, 2013, 06:41:47 pm
« Reply #7 on: April 05, 2013, 06:41:47 pm »
100% correct..
