Author Topic: Rad Fan swaps.  (Read 4947 times)
Reply #15January 05, 2009, 06:45:35 pm
lildevil
  • 49
Rad Fan swaps.
« Reply #15 on: January 05, 2009, 06:45:35 pm »
Quote from: "53 willys"
Quote from: "TurboJ"
Anyone have good pictures of the Passat twin fans?
Are they really slim and do they come with a deep shroud or is it really a 'space saver' design?
Nobody...?
I will grab some pics of mine tomorrow....mine is NOT the direct bolt in replacement...I had to make 2 small extender tabs to make mine mount in factory locations...
I put a passat dual fan into mine, its MUCH smaller and keeps it cool much faster, mines holding in with 3 screws though, forth one isnt lined up, BUT you could use the Passat rad aswell if you like
Delmonte...Some Serious *** My Friend
Reply #16January 09, 2009, 08:23:16 am
53 willys
Rad Fan swaps.
« Reply #16 on: January 09, 2009, 08:23:16 am »
here is my passat fan...mine came from a 93 with a 16v..but i still had to mod the passenger side mounts to fit.
here is the spot that needed to be modded
Reply #17January 09, 2009, 09:47:46 am
TurboJ
  • 661
Rad Fan swaps.
« Reply #17 on: January 09, 2009, 09:47:46 am »
Thanks! That is helpful.
The Passat fan isn't really that slim after all..
But it's sure to be effective. Will have to see if that works for me too.
Jetta II 1.6 TD 'Project 200'
Reply #18January 09, 2009, 10:00:33 am
53 willys
Rad Fan swaps.
« Reply #18 on: January 09, 2009, 10:00:33 am »
I think the MK3 gasser fan is smaller and direct bolt in???
Reply #19January 09, 2009, 11:52:21 am
TurboJ
  • 661
Rad Fan swaps.
« Reply #19 on: January 09, 2009, 11:52:21 am »
I guess I'll have to go on a breaker's yard tour soon  8)
Reply #20January 09, 2009, 03:09:48 pm
Quantum TD
  • 1195
Rad Fan swaps.
« Reply #20 on: January 09, 2009, 03:09:48 pm »
Not really. The MK3 is taller and won't fit without trimming the bottom (or top?) off the shroud.
Reply #21January 09, 2009, 07:25:08 pm
  • 3468
    • McScrubbins Body Wash
Rad Fan swaps.
« Reply #21 on: January 09, 2009, 07:25:08 pm »
well a bit of trimming isn't too difficult!
I'm still :roll:  waiting to make a shroud with my friend. I need to buy some stock.
Reply #22January 11, 2009, 08:39:22 am
TurboJ
  • 661
Rad Fan swaps.
« Reply #22 on: January 11, 2009, 08:39:22 am »
I got a Passat TD twin fan now too. It looks pretty nice and at least it should be very effective.
The only thing I don't like about it is the big fan motor that protrudes a long way into the engine compartment. I wonder why universal 'slim' fans only need a tiny motor on them. If only I had some reserve in my project budget I would look into fitting universal slim fans into the Passat twin shroud.
Now I think I'm just going to go with the Passat system.
Reply #23January 11, 2009, 09:48:37 am
53 willys
Rad Fan swaps.
« Reply #23 on: January 11, 2009, 09:48:37 am »
most aftermarket fans SUCK!! I have spent big bucks on fans in my day...and I have come to the conclusion that stock fans truly do pull the most CFM....my passat fan is thicker then the other style....so there is thinner versions.
in the end I like the thicker one since it has a REAL nice enclosed shroud.
I would take a pasasat fan or taurus fan over a high dollar flexalite or spal fan ANY day.
my .02
hey zukgod1!! post a pic of you bolt in passat fan would yah?!?!?!?!?
that way we can all see the difference.
Reply #24January 11, 2009, 09:43:08 pm
Powjetta
  • 152
    San Diego CA
Rad Fan swaps.
« Reply #24 on: January 11, 2009, 09:43:08 pm »
I installed the newer passat dual fan with the blades tied on the outer edges with very minor modifications to mounts.  I have no problem keeping the rad and coolant temp down but have burned out 2 alts before going to a Bosch.  It does fine on low speed but when high kicks on it sucks juice and my voltage drops.  I am thinking of disabling the high speed.  AC blows cold even today at 80 deg.  I bought the passat controller but haven't opened it up yet to see what the magic is.
'86 jetta 2 dr Turbo diesel K24 - sold
'94 GMC 6.56TD - sold
Reply #25January 13, 2009, 08:26:55 pm
Powjetta
  • 152
    San Diego CA
Rad Fan swaps.
« Reply #25 on: January 13, 2009, 08:26:55 pm »
I took the opportunity to check the draw on the dual fan set up that I have, low draws 36 amps and high draws 55 amps total draw with AC on high blower speed.   My Bosch 90 amp alternator puts out about 36 at idle and on high speed and at idle I believe it is drawing from the battery.  After I let it sit at idle and then rev it up I saw a brief high of 75 amps with the clamp meter on the alt wire.   Slightly different numbers on the positive cable due to the juice in the battery.  I put a switch in to activate high speed but I don't use it since installing the dual fan.
Reply #26January 14, 2009, 07:58:06 am
Rad Fan swaps.
« Reply #26 on: January 14, 2009, 07:58:06 am »
my .02
I'll see if I can get one today. I'll have to use the phone but should be ok.
Reply #27January 17, 2009, 01:57:21 am
carrizog60
  • 978
Rad Fan swaps.
« Reply #27 on: January 17, 2009, 01:57:21 am »
i bought one from passat vr6 wih a/c and its slimmer...
and as 3 speeds...
Portugal
