Author Topic: Common Check engine light problems?  (Read 16839 times)
Reply #15November 19, 2008, 01:29:28 am
  • 3468
    • McScrubbins Body Wash
« Reply #15 on: November 19, 2008, 01:29:28 am »
bump?  :(
Reply #16November 19, 2008, 10:18:17 am
  • 3468
« Reply #16 on: November 19, 2008, 10:18:17 am »
I disconnected the battery for 10 minutes and after 30 seconds of running the engine light came on again  :(
sigh, oh well.
Thanks guys.
Reply #17November 19, 2008, 10:36:22 am
  • 1739
« Reply #17 on: November 19, 2008, 10:36:22 am »
you could try disconnecting both battery terminals ,wait 5 seconds, touch them together [make sure neither one is still attached to the battery] for 10 seconds, them reconnect to battery.
Reply #18November 19, 2008, 10:39:46 am
  • 3468
« Reply #18 on: November 19, 2008, 10:39:46 am »
well, i took the negative off and left it.
The clock in the dash read 12:00
Would taking both off and touching them together still make a difference?
Reply #19November 20, 2008, 07:18:59 am
  • 1739
« Reply #19 on: November 20, 2008, 07:18:59 am »
Yes if you REMOVE both  from the battery and touch them together with even just a small gauge wire it should kill any memory in the ECM
Reply #20November 20, 2008, 07:54:16 am
« Reply #20 on: November 20, 2008, 07:54:16 am »
Quote from: "the caveman"
It will help if you have the key in th "On" position as well.
Reply #21November 20, 2008, 07:46:31 pm
Tintin
  • 1279
« Reply #21 on: November 20, 2008, 07:46:31 pm »
I dont think disconnecting the battery or even 50 cycle ignition can erase the code in OBD2, it work for the older car and truck below 1997 or 1996 but not after.
Anyway the code will reappear again and again if you do not fix the real problem.
Reply #22November 20, 2008, 08:28:21 pm
  • 3468
« Reply #22 on: November 20, 2008, 08:28:21 pm »
Quote from: "Tintin"
But i thought i did fix the real problem?
A dead glow plug... i found it and changed it...
Edit: Tintin is right. I did connect them together and the light still comes on.
Reply #23November 21, 2008, 08:16:45 am
« Reply #23 on: November 21, 2008, 08:16:45 am »
Ya it's going to need to be reset with a VAG I'm guessing.
Reply #24November 21, 2008, 01:49:40 pm
  • 3468
« Reply #24 on: November 21, 2008, 01:49:40 pm »
shucks. Thanks anyhow guys!!! really appreciate it. hope i can help you all somtime
