Author Topic: how does this turbo map look?  (Read 3013 times)
November 11, 2008, 11:54:47 pm
monomer
  • 414
« on: November 11, 2008, 11:54:47 pm »
For a 1.6td build (turbo bottom end, 8v turbo log mani - 38mm wastegate)
www.michiganvw.org
Reply #1November 12, 2008, 06:07:16 pm
monomer
  • 414
« Reply #1 on: November 12, 2008, 06:07:16 pm »
none of the turbo guys are gonna chime in?
www.michiganvw.org
Reply #2November 12, 2008, 06:53:34 pm
jackbombay
  • 599
« Reply #2 on: November 12, 2008, 06:53:34 pm »
The pressure ratio is not particularly high, above 3 is what you should be looking for.
   Is the X scale cubic meters? Do you have a higher res image of the map?
  If you can confirm what the X scale is I can plot a few points on the map for you.
Reply #3November 12, 2008, 08:32:39 pm
monomer
  • 414
« Reply #3 on: November 12, 2008, 08:32:39 pm »
thats a screendump from a pdf
anyone know where to host a pdf?
Volumetric Flow m3/min is labeled on the bottom
www.michiganvw.org
Reply #4November 14, 2008, 02:55:33 pm
flapjack
  • 283
« Reply #4 on: November 14, 2008, 02:55:33 pm »
I can host it for you
email it to
[email protected]
signature
Reply #5November 14, 2008, 04:04:20 pm
monomer
  • 414
« Reply #5 on: November 14, 2008, 04:04:20 pm »
sent
www.michiganvw.org
Reply #6November 14, 2008, 04:47:01 pm
flapjack
  • 283
« Reply #6 on: November 14, 2008, 04:47:01 pm »
click for TURBO PDF
and here is a slightly better screenshot of it
signature
Reply #7November 17, 2008, 09:07:36 pm
monomer
  • 414
« Reply #7 on: November 17, 2008, 09:07:36 pm »
any better?
www.michiganvw.org
Reply #8November 19, 2008, 06:00:10 pm
monomer
  • 414
« Reply #8 on: November 19, 2008, 06:00:10 pm »
^ANYONE?
www.michiganvw.org
Reply #9November 19, 2008, 06:05:21 pm
« Reply #9 on: November 19, 2008, 06:05:21 pm »
Drop jackbombay a PM. He's pretty good with maps.
Reply #10November 19, 2008, 06:53:05 pm
Jet A
  • 125
« Reply #10 on: November 19, 2008, 06:53:05 pm »
Id run it.
Should have plenty of range for your motor.
85 vw golf NA ----> 2b TD  Daily Driver
Converted to hydraulic head (Thanks zukgod1)
td04 turbo, Zex nitrous (for the big hills), PITA motor, fresh rings w/ ceramic pistons.
Custom Intake and Exhaust
Ported and polished head
Dipricol EGT, FP, Boost,
Autometer, Oil Temp, Water Pressure
Reply #11November 19, 2008, 08:33:22 pm
monomer
  • 414
« Reply #11 on: November 19, 2008, 08:33:22 pm »
Quote from: "Jet A"
Id run it.
$300 NEW...
www.michiganvw.org
Reply #12November 19, 2008, 09:57:58 pm
blkboostedtruck
  • 1535
« Reply #12 on: November 19, 2008, 09:57:58 pm »
i've ran one but on a gasser! it is a quick spooling turbo!
but i don't think the turbo's last very long? when i got my truck it had one on it! and it also had 3 trashed core's with it for parts! and even the one that was on it took a dump! so i redone the manifold so it would fit a K26 and i never had a problem since!
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #13November 20, 2008, 05:03:55 pm
monomer
  • 414
« Reply #13 on: November 20, 2008, 05:03:55 pm »
Quote from: "blkboostedtruck"
Duane
hmmmmm, my other garrett has lasted 400k miles
sounds like you have problems...
www.michiganvw.org
Reply #14November 20, 2008, 05:06:35 pm
« Reply #14 on: November 20, 2008, 05:06:35 pm »
Quote from: "monomer"
That goes without saying!   :lol:  :lol:  :lol:
