Author Topic: Brake Proportioning Valve  (Read 7680 times)
November 10, 2008, 11:46:01 am
AndrewSE
« on: November 10, 2008, 11:46:01 am »
Hey guys !
Been working on my brakes for the past few weeks....kinda went on me 2 weeks ago.
Had to change my MC and most of my back lines. My Brake Proportioning Valve is seized and I can't even get 3 out of the 4 lines off and it looks like a ball of rust. Was told it should be changed.
any suggestions on parts in the GTA ??? I went to a place called Frisco and got a quote of 130ish
while I have most of my system apart, any suggestions on anything else I should change ?
Reply #1November 10, 2008, 12:20:18 pm
« Reply #1 on: November 10, 2008, 12:20:18 pm »
good time to change the lines as well...  :lol:
Reply #2November 10, 2008, 12:23:20 pm
AndrewSE
« Reply #2 on: November 10, 2008, 12:23:20 pm »
oh yeah ! I kinda have no choice
the PO changed the half of em, but the other ones are nasty and broke when I removed the Brake Proportioning Valve.
gotta love rust.
Reply #3November 10, 2008, 03:49:34 pm
« Reply #3 on: November 10, 2008, 03:49:34 pm »
The joys of Canadian winters 8)
We can get parts at performance diesel, www.autopartsonlinecanada.com is a good sites
Reply #4November 10, 2008, 04:35:19 pm
clbanman
  • 705
    Cambridge, Ontario
« Reply #4 on: November 10, 2008, 04:35:19 pm »
Problem is they don't carry the proportioning valve.   What I did is go to http://www.altrom.com/models.jsp?makeId=421, click on your vehicle model, then "brakes control" along the left.  That should give you a page that has a "pressure regulator valve" like http://www.altrom.com/partdetails.jsp?id=1118.  Then at the top of the page, click the tab for find a retailer, enter your postal code, and you'll know where to spend your money.  I paid $137 with taxes at Partsource.  If you have a bit of time, you may find one cheaper on eBay, but I don't know how much you'd save by the time you pay shipping, exchange and duty. http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=260237853359
My original was so rusty that the 10 mm nuts on the ends of the brake lines were small enough to let a 9 mm wrench slip over the hex.  I ripped it all out and replaced it.  Got to love salt on the roads in the winter.
Calvin
91 VW Golf 1.6NA 5spd
Reply #5November 10, 2008, 06:04:02 pm
Dakotakid
  • 1240
« Reply #5 on: November 10, 2008, 06:04:02 pm »
What car and what country, eh???? Arizonaautohaus in Phoenix, I think has them for $100 for Mk. II Jettas (can't remember......). I needed one last year.
Reply #6November 10, 2008, 06:13:25 pm
Dakotakid
  • 1240
« Reply #6 on: November 10, 2008, 06:13:25 pm »
For an '86 Jetta: $70.29 for Obama bucks.........
Reply #7November 11, 2008, 06:45:51 am
AndrewSE
« Reply #7 on: November 11, 2008, 06:45:51 am »
Cool stuff guys !
did some searching lastnight and found a place for 110.00 plus tax local to me.
thanks for the feedback I have a good idea as to what I should be paying in CDN dollars.
Reply #8November 11, 2008, 11:43:59 am
« Reply #8 on: November 11, 2008, 11:43:59 am »
a little off topic here, but has anyone experimented with coatings for brake lines/parts to inhibit rust?  i was thinking of an epoxy coat for brake lines... good idea? bad?
i was also thinking about one of those electronic rust inhibiters... since the brake lines are grounded
Reply #9November 11, 2008, 12:46:21 pm
AndrewSE
« Reply #9 on: November 11, 2008, 12:46:21 pm »
A guy I work with has one of the electronic rust control things on his car. Not sure if they really work since his car is just 3 or 4 years old. Mind you it is cavalier  :twisted:
Its funny you mentioned coating the lines. I was thinking the same thing after I'm done with installing my new lines.
I picked up a can of Rust check undercoating for when I replaced my driver’s side floor. I used that and the spreading foam to fill the minor gaps and to protect the area around that I cut out. Oh and about 6 things of roofing tar... that’s another story.
back to my original point about the rust check stuff. It puts a nice thin coat that bonded well to the under side. I took the time to do the lines that where replaced already and it seems to do the trick. Time will tell if it really helps.
Reply #10November 11, 2008, 01:22:25 pm
« Reply #10 on: November 11, 2008, 01:22:25 pm »
Quote from: "AndrewSE"
i've wondered if anything will really stick to brake lines properly, as they can get a bit hot at times... i figured why not (just before installing them - AFTER bending them to the right shape) dip them in some kind of sealant/paint, or even powder coat them? bullet proof brake lines would be kick ass up here in Canada  :wink:
Reply #11November 12, 2008, 12:05:24 am
  • 2932
« Reply #11 on: November 12, 2008, 12:05:24 am »
You can get brake lines with great coatings on them.
