Author Topic: Gasket between turbo and manifold  (Read 3107 times)
November 05, 2008, 05:57:30 am
ObscuredByClouds
  • 98
« on: November 05, 2008, 05:57:30 am »
Where can I get the gasket that goes where the turbo bolts to the exhaust manifold?
Reply #1November 05, 2008, 07:01:52 am
TurboJ
  • 661
« Reply #1 on: November 05, 2008, 07:01:52 am »
In the case of the stock TD trapezoidial turbo flange, your only option will be a VW dealer.
Jetta II 1.6 TD 'Project 200'
Reply #2November 05, 2008, 07:37:11 am
arb
« Reply #2 on: November 05, 2008, 07:37:11 am »
I have seen them on ebay...
Reply #3November 05, 2008, 07:44:15 am
« Reply #3 on: November 05, 2008, 07:44:15 am »
There available but not necessary.
There wasn't one there from the factory.
Reply #4November 05, 2008, 09:57:47 am
« Reply #4 on: November 05, 2008, 09:57:47 am »
Quote from: "zukgod1"
Exactly. It's not needed. Both surfaces are suppose to be precision ground though
Reply #5November 05, 2008, 10:54:02 am
  • 3468
    • McScrubbins Body Wash
« Reply #5 on: November 05, 2008, 10:54:02 am »
Quote from: "libbybapa"
I hand lap the sealing surfaces and use a light smear of Permatex Ultra Copper.  I've never had one leak.
Andrew
That sounds the best option to meeeeeeeee
I'm going to do that now.
Reply #6November 05, 2008, 11:16:36 am
53 willys
« Reply #6 on: November 05, 2008, 11:16:36 am »
Reply #7November 05, 2008, 11:35:48 am
  • 3468
« Reply #7 on: November 05, 2008, 11:35:48 am »
I just realized what we were talking about.
I ordered that from Prothe two weeks ago. I thought they were the inside gaskets of the turbo.
Reply #8November 05, 2008, 01:04:52 pm
« Reply #8 on: November 05, 2008, 01:04:52 pm »
I think if you are having a leak and cant take it appart to lap the surface's then Prothe's gaskets are good but if your not experiencing a leak there is no reason.
On the other hand I can see there being a leak after using a gasket as the metal may flex around the sealing surface of the gasket causing it to warp ever so slightly so next time you wont have a choice to either lap the surfaces or get gaskets again.
Reply #9November 05, 2008, 03:39:54 pm
dillenger1
  • 777
« Reply #9 on: November 05, 2008, 03:39:54 pm »
Quote from: "Smokey Eddy"
eddy,are you rebuilding your turbo?I have to ask why you bought the gasket?
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #10November 05, 2008, 05:32:43 pm
  • 3468
« Reply #10 on: November 05, 2008, 05:32:43 pm »
I'm not rebuilding the turbo (Edit: anymore that is. i don't know what im doing and since there is no play in the shaft i don't have to). I thought there were gaskets that i had to replace when i took it off the head but as stated you don't need to... so ... i guess i wasted 10 bucks.
However, the square one did come off my set up at some point and it looks pretty beat.
Reply #11November 19, 2008, 07:45:41 pm
Jettagli16v
  • 344
« Reply #11 on: November 19, 2008, 07:45:41 pm »
went through this for a few weeks awhile ago...
- My VW Dealership does not list a gasket in the ETKA. (They printed the picture for me) They said there is not one there.
-Local german parts stores that can get all german parts, could not get it.
- No diesel shop in town (even the guys who do garrett turbos) has the gasket.
I bought one from Prothe off EBAY. he shipped the wrong one, (K03, not T3) and I ended up buying another set to get them ASAP.
If you have a K03, I will happily send you these gaskets, just return what I paid.
