Author Topic: Quick Head Port & Polish Question  (Read 3847 times)
June 28, 2005, 09:23:24 am
  • 1156
    • Malone Tuning Ltd.
« on: June 28, 2005, 09:23:24 am »
Should I leave the polishing to exhaust ports only? For TDIs, I believe polishing intake ports are acceptable as long as the swirl port design is left alone, but for TDs I'm not so sure. I realize that in a IDI head fuel is injected outside of the intake air stream, but I would assume that air swirl/tumble is still important for the later mixture with low pressure fuel. Comments?
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #1June 28, 2005, 09:31:28 am
935racer
« Reply #1 on: June 28, 2005, 09:31:28 am »
With the TD's I would think its best to do both, I think the intake would benefit from a good polish. I'll match them all at least mark.
Reply #2June 29, 2005, 07:53:53 pm
SMOKEYDUB
  • 630
« Reply #2 on: June 29, 2005, 07:53:53 pm »
The turbo will make it tumble :wink:
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #3July 02, 2005, 12:15:15 pm
Northboundtrain
  • 131
    • http://boulderbiodiesel.com
« Reply #3 on: July 02, 2005, 12:15:15 pm »
Quote from: "935racer"
Do you mind explaining what this means?  I'm trying to learn all I can about porting and polishing.  Thanks
'75 Chevy 3/4 ton 6.5L conversion
'91 Jetta 1.6L NA
Biodiesel
"The fool who persists in his folly will become wise." -Blake
Reply #4July 02, 2005, 02:15:38 pm
Baxter
« Reply #4 on: July 02, 2005, 02:15:38 pm »
Match porting is where you match manifold to the ports on the head.
Simplest way to do it is to colour the area around the port with a black marker.
Place the gasket over the studs and using a scribe then mark out all the metal protruding past the gasket.
Then, with a die grinder remove metal till the gasket matches the head.
repeat for all ports on head and manifold.
Basically your removing steps that could impede the free flow of gas in or out of the engine.
Reply #5July 02, 2005, 06:09:24 pm
Northboundtrain
  • 131
« Reply #5 on: July 02, 2005, 06:09:24 pm »
Thanks, I was wondering how that was done.  Does the gasket ever compress and squeeze out into the port?  Is it worth polishing the manifolds too?
'91 Jetta 1.6L NA
Biodiesel
Reply #6July 05, 2005, 01:43:43 pm
Baxter
« Reply #6 on: July 05, 2005, 01:43:43 pm »
Yep, Manifolds too.
Don't go mad, I generally just give stuff a quick fettle while the heads off.
Im no engine modifier by a long shot, just a general repair garage.
Not dealing with modifying heads daily I can't tell where the weak spots are, you gotta be careful porting heads as you can grind through into the water jacket or oil ways... not good!
Just take out rough edges, casting marks and blemishes and a quick tidy up is enough for me.
Another trick is to "waste" the valve guides to improve flow, some people grind the whole lot off that protrudes into the port, okay on a rarely used and regularly stripped race engine, not good for a daily drive!
