Author Topic: injectors  (Read 6385 times)
October 29, 2008, 05:32:51 pm
turborabbit
  • 41
injectors
« on: October 29, 2008, 05:32:51 pm »
Hey, virtual gurus, thanks for the tach tips. Now I need help with my injectors. The engine is a 1.6T diesel out of an '86 Jetta. #2 and#3 are leaking, though I did get 51.7 on the second tankfull. I have some injectors from my other  caddys, but they are 115bar and 130bar. My spare 1.6T has 155bar injectors. Can I mix and match? Will I get better or worse economy? Can they be re-built or do I need new ones?? huh? huh? are we there yet??arewethereyet??
If "the more you know, then the more you know, you don't know, then I've got a lot to learn, since I'm forgetting what I thought I knew!!
01Dodge TD
81 Caddy TD
84 Winnebago/Renault TD
86Jetta84GolfCaddyCaddyCaddyCaddy
Reply #1October 29, 2008, 05:57:00 pm
injectors
« Reply #1 on: October 29, 2008, 05:57:00 pm »
i wouldn't mix and match, although the engine would probably still run, it will most likely run rough.  however it is better than running with a leaky injector (as a leaky injector can damage the motor severely)
Reply #2October 29, 2008, 06:17:56 pm
turborabbit
  • 41
injectors
« Reply #2 on: October 29, 2008, 06:17:56 pm »
Thanks for the reply. What is the significance of the bar rating??
01Dodge TD
81 Caddy TD
Reply #3October 29, 2008, 06:28:11 pm
injectors
« Reply #3 on: October 29, 2008, 06:28:11 pm »
Quote from: "turborabbit"
its the pressure at which the injector opens.  the higher the pressure, the longer it takes to build, the lower pressure, the less time it takes to build.  turbo injectors have higher to ensure a 'safe' atomization with all the boost.
by mixing, you'll be affecting the timing.  a few bar difference between injectors isn't so bad, but more than 20 will really make it run rough and 'weird'.
Reply #4October 29, 2008, 06:33:01 pm
turborabbit
  • 41
injectors
« Reply #4 on: October 29, 2008, 06:33:01 pm »
Will the 130bars give me more fuel economy??
01Dodge TD
81 Caddy TD
Reply #5October 29, 2008, 07:36:24 pm
cyrus #1
  • 360
injectors
« Reply #5 on: October 29, 2008, 07:36:24 pm »
Potentially they could since it would take less power to compress to 130 instead of 155.  It's hard to say if you would actually notice any difference though.  I suspect the biggest difference you would see would be from a nice set of rebuilt injectors.
The injector nozzles can be replaced as they are wear items.  This is probably a good idea if the mileage is high.  If you check the for sale section, there is a group buy for injector nozzles right now.  :D
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #6October 29, 2008, 07:54:07 pm
injectors
« Reply #6 on: October 29, 2008, 07:54:07 pm »
there was a post done a while back by i think subsonic with regard to pop pressures and fuel economy... and i think that 130 bar was the most economic.  higher breaking pressures = parasitic drag.  but those pressures are there for a reason.  i would love to see experiments of injecting fuel into regular atmospheric pressure, and then seeing the effects of going 10 psi, 20 psi, 30 psi, etc...
Reply #7October 29, 2008, 08:39:53 pm
beew
  • 27
injectors
« Reply #7 on: October 29, 2008, 08:39:53 pm »
a higher opening pressure would reduce the injection period and will also more easily overcome cylinder pressures. im not sure of the effect of this on performance or fuel economy if it is even noticeable.
94 Jetta GL diesel
Reply #8October 29, 2008, 08:58:40 pm
cyrus #1
  • 360
injectors
« Reply #8 on: October 29, 2008, 08:58:40 pm »
Quote from: "jtanguay"
I think it would also be interesting to build a see through pressure vessel for testing injections. Pressurize it to 500 psi and see if the fuel sprays any differently than into the atmosphere.  That could get pretty dangerous though.  :twisted:
Cody
2002 Jetta TDI
Reply #9October 29, 2008, 10:18:18 pm
injectors
« Reply #9 on: October 29, 2008, 10:18:18 pm »
Quote from: "cyrus #1"
500 psi hmmm you'd need some diving aparatus or something  :lol:
i guess going 10 psi 20 psi or 30 psi isn't going to be the same  :oops: i forgot that it needs to be multiplied! so... 14.7psi is normal.  now if you go 30 psi, does the compression numbers rise to 1000 psi??? thats pretty insane...
Reply #10October 30, 2008, 07:55:56 pm
AdAm84
injectors
« Reply #10 on: October 30, 2008, 07:55:56 pm »
I have some full SCUBA tanks. They are 2250psi :lol:
Reply #11October 31, 2008, 07:00:02 pm
injectors
« Reply #11 on: October 31, 2008, 07:00:02 pm »
Quote from: "AdAm84"
so using that, and a small cutout for a sight glass, this could work... BUT i forgot the fundamental flaw... the diesel will autoignite!!!   :shock:  :lol: unless the air is let cool long enough...
Reply #12November 01, 2008, 12:43:09 pm
AdAm84
injectors
« Reply #12 on: November 01, 2008, 12:43:09 pm »
Yeah slight flaw in the design. But would be cool to see...... from across the shop  :lol:
