Hi guys. My brother's A2 Golf (1990) IDI has been rattling loose the a/c,alt bracket bolts, and he didn't heed my advice and have me check the bolts every month, and now he's screwed. The bolt that that holds the A/C compressor to the bracket on the passenger side has snapped off in the bracket (well inside the threads). I'd like to remove the whole bracket so I can clean it up properly (so I can use loctite on those damn bolts!), and remove the broket bolt. I removed the compressor, and alt, but it doesn't seem possible to remove the bracket without removing the injection pump. Am I correct in assuming this?
If I do indeed have to remove the IP, can I simply bolt everything back where it was and not have to worry about timing the pump? I don't have the tools or experience to do this.
Any advice would be greatly appreciated. I'm sick at the moment, and it's damn cold outside, which makes working on the car a pain in the ass...
Thanks!
Mark.
