I just did a conversion from a 1.6gtd to a 1.9gtd and bumped into a few problems! :shock: So the original engine was a 1.6 gtd '89. i wanted to do the transfer because i wanted more power and the old 1.6 oil consumption was very bad.I bought a 1.9 td engine from a guy without IP and other stuff, just block and head! I did a complete overhaul on the engine and now it is like new.THE PROBLEMS:1. the turbo (garret T3) does not fit. it bumps on the intake manifold so doesn't go enough for the 4 bolts to fit.What i did is just grind the side of the turbo and the intake manifold to create enough space. I saw someone on the forum made an adapter but the grinder was the easiest way out! :oops: PROBLEM SOLVED!2. The backplate for the timing cover from my 1.6 does not fit on the 1.9. I guess this is because the block is tallerSolution for now: Drive without a timing cover :cry: Any suggestions on this???
4. I had to use the IP from the 1.6 and bend the fuel lines a bit. Is this going to be a limitation for performance?? Is the 1.6 pump going to deliver enough fuel for the 1.9? Help!!!!
I had a bird strike @ 80+mph that put bird parts and perhaps some grill that got into a fully installed timing cover (inside and outside covers) and make the pump retard on tooth.Holy ski high boost and EGT Batman. Ran like crap too.
i think it was veeman who had sucked up a plastic bag while on the freeway and then made his timing belt slip because he didn't have the cover on. man that is some BAD luck! but just warning you of what can happen without it on. the chances of that happening are pretty slim though.
how much did you pay for the block and head, if you dont mind me asking?
