Author Topic: Proportioning valve or pressure reducing valve  (Read 11020 times)
Reply #15November 09, 2008, 03:12:52 pm
clbanman
  • 705
    Cambridge, Ontario
« Reply #15 on: November 09, 2008, 03:12:52 pm »
Yes the top lines go to the wheel cylinders, the bottom to the master cylinder.  This http://www.altrom.com/partdetails.jsp?id=1118 is the replacement I bought.  When I push the lever in to try and line the holes up, I can't push it far enough by hand to get them to line up.  How much force should I use?
Calvin
91 VW Golf 1.6NA 5spd
Reply #16November 09, 2008, 04:33:01 pm
« Reply #16 on: November 09, 2008, 04:33:01 pm »
Quote from: "clbanman"
how much did you get that one for???
Reply #17November 09, 2008, 07:14:34 pm
clbanman
  • 705
    Cambridge, Ontario
« Reply #17 on: November 09, 2008, 07:14:34 pm »
Partsource.  $137 with all taxes.
Calvin
Reply #18November 10, 2008, 07:57:19 pm
madmedix
  • 204
« Reply #18 on: November 10, 2008, 07:57:19 pm »
Sorry, forgot to add: took me on my back, with my fingers curled around the top of the regulator, it took both thumbs pressing up hard and my helper to slide the zip tie through.
Andy
'90 TD Jetta
Reply #19November 14, 2008, 02:13:47 am
Josh
  • 54
« Reply #19 on: November 14, 2008, 02:13:47 am »
Did anybody consider installing a cheaper brake proportioning valve, such as those marketed by various "hot rod" retailers?  You can get one with 3/16 fittings and a rotary adjustment dial to dial in a decent balance... for around $40.
Is this setup, the stock setup, really that much more functional?
I've got to redo some rear brakes this week, and was leaning towards this approach, which is why I ask.
-Josh
'84 Quantum sedan (oops, not '83!)
'83 Quantum wagon(ditto, not '82)
'82 Westfalia
'79 Rabbit
Mmmm.  Diesely.
Reply #20November 14, 2008, 03:19:07 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #20 on: November 14, 2008, 03:19:07 am »
I think most of the "hot rod" ones you are talking about are designed for a single line to the rear brakes.  Your car will have two.  If you did go this way, the setting is adjustable but fixed once the hood is closed.  The stock version is supposed to be self-adjusting for varying rear axle loads/positioning.   I suppose you could plumb in two of these, one for each side of the VW circuit - IE: one for left front/right rear and one for right front/left rear - but I think your cost savings is diminishing.
Calvin
Reply #21November 14, 2008, 12:02:23 pm
Josh
  • 54
« Reply #21 on: November 14, 2008, 12:02:23 pm »
Ah, I see!  Thanks for the insight; I shall go with OEM-style for certain, then.
'82 Westfalia
'79 Rabbit
Mmmm.  Diesely.
Reply #22November 28, 2008, 05:38:14 pm
madmedix
  • 204
« Reply #22 on: November 28, 2008, 05:38:14 pm »
bump...seen a couple of posts on this and I found an old bookmark file with this in it: http://www.bmw-m.net/TechProc/bleeder.htm
Neat little home-made pressure bleeder...
'90 TD Jetta
Reply #23December 01, 2008, 06:22:46 pm
jasonsansfleece
  • 162
« Reply #23 on: December 01, 2008, 06:22:46 pm »
Any reason why one could'ent use Golf type valves (on master cylinder) on a Jetta? Junk all that nonsense under the car?
Guy
Reply #24December 02, 2008, 03:17:40 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #24 on: December 02, 2008, 03:17:40 am »
They would work, but you would lose the self-adjusting feature.  The two you would need would also cost more than the one under the car, at least they did from my supplier.
Calvin
