Author Topic: it modifies mk1  (Read 19775 times)
Reply #30January 24, 2009, 08:49:10 am
sabatino
it modifies mk1
« Reply #30 on: January 24, 2009, 08:49:10 am »
:cry: hello boys please help help
Reply #31January 24, 2009, 06:25:52 pm
  • 3468
    • McScrubbins Body Wash
it modifies mk1
« Reply #31 on: January 24, 2009, 06:25:52 pm »
whew! This is really difficult!
I wish there was a real person who could translate, not google translate.
Remember when you use google translate, Sabatino, make sure you use exact grammar or else it will not translate and we don't know what you want to say!
I am just taking a wild stab in the dark here...
You want to make a mechanically controlled VNT turbo, correct?
Or, you are asking for picture (foto) , schematic (schema) of the electronics of the pump and vnt turbina?
as I have to connect only electric plant for pomp and turbina?esiste schema,foto,manuale of solution?
you excuse for the translation
It would be easier to NOT use the tdi turbina.
We want to help Sabatino, it's just very difficult to understand. :(
Reply #32January 25, 2009, 02:59:41 am
sabatino
it modifies mk1
« Reply #32 on: January 25, 2009, 02:59:41 am »
:D  thanks Smokey Eddy,thanks to all of you you are really kind
 scheme serves me to connect pomp tdi and turbine (also only pomp) from the original ecu
can you help me?
I beg you help help
now I am translating with a program that calls L&H Power Translator Pro
Reply #33January 25, 2009, 03:24:51 am
sabatino
it modies mk1
« Reply #33 on: January 25, 2009, 03:24:51 am »
boys tried to tyradurre by Italian to your language:
ho modificato i freni del mio mk1 con i freni a disco di un mk2 gti,
la mia car non ha il correttore di frenata,posso fare qualche
miglioramento? devo montare correttore?
(I have modified the brakes of my mk1 with the brakes to disk of a mk2 gti,
my car doesn't have the proofreader of frenata,posso do some
improvement? do I have to climb on proofreader?)
that in Italian you/he/she is translated in parenthesis, we try if it is all right
Reply #34January 28, 2009, 09:31:50 pm
giulianot
  • 146
it modifies mk1
« Reply #34 on: January 28, 2009, 09:31:50 pm »
i think you are asking if the rear proportioning valve is needed when installing mk2 rear discs  on a mk1??
I would say that you need the proportioning valve (correttore di frenata) from a mk1 scirocco with rear discs.
1990 cabriolet 1.9 aaz, kkk 24/26,  Giles pump, big  2.5" intercooler,  3 " P.P. downpipe
Reply #35January 28, 2009, 11:06:11 pm
it modifies mk1
« Reply #35 on: January 28, 2009, 11:06:11 pm »
yea the proportioning valve is a key element to the braking system.  too much rear brake will make the ass end break loose on hard braking.
Reply #36January 29, 2009, 12:31:20 pm
sabatino
it modifies mk1
« Reply #36 on: January 29, 2009, 12:31:20 pm »
thanks reserved ragazzi,ho new correttote for mk1
just ended I make you know
p.s.Giulianot I have sent you messages time fa,non you ever have risposto,non you have received?
Reply #37January 29, 2009, 12:33:46 pm
sabatino
it modifies mk1
« Reply #37 on: January 29, 2009, 12:33:46 pm »
boys help modifies with pomp and turbine tdi
have I taken the whole plant as he connects?
help help help
Reply #38January 30, 2009, 02:53:26 pm
sabatino
it modifies mk1
« Reply #38 on: January 30, 2009, 02:53:26 pm »
Reply #39January 30, 2009, 02:57:12 pm
sabatino
it modifies mk1
« Reply #39 on: January 30, 2009, 02:57:12 pm »
Reply #40January 30, 2009, 03:05:24 pm
sabatino
it modifies mk1
« Reply #40 on: January 30, 2009, 03:05:24 pm »
Quote from: "sabatino"
 from this car I have taken electric motore,cambio,ecu,impianto for accelleratore elettronico,misuratore massa  aria,pedaliera
Reply #41January 30, 2009, 03:06:52 pm
sabatino
it modifies mk1
« Reply #41 on: January 30, 2009, 03:06:52 pm »
motor tdi in my car diesel golf1
Reply #42January 30, 2009, 03:09:33 pm
sabatino
it modifies mk1
« Reply #42 on: January 30, 2009, 03:09:33 pm »
my car mk1
Reply #43January 30, 2009, 03:25:06 pm
sabatino
it modifies mk1
« Reply #43 on: January 30, 2009, 03:25:06 pm »
Reply #44January 31, 2009, 09:21:54 pm
dillenger1
  • 777
it modifies mk1
« Reply #44 on: January 31, 2009, 09:21:54 pm »
you should send me one of those motors! :D
1.6td in toyota pickup
10mm head ,t3 intercooled.
S-PAutomotive.com
