Author Topic: it modifies mk1  (Read 28148 times)
October 17, 2008, 05:05:54 am
sabatino
it modifies mk1
« on: October 17, 2008, 05:05:54 am »
hi to tutti,vorrei to climb on a motor tdi on my mk1d year 1982,
which changes do I have to do?
I accept your suggestions and esperinze in the field aspect with anxiety your answers
cordially Sbatino. :D
Reply #1October 18, 2008, 09:48:35 am
sabatino
it modifies golf1
« Reply #1 on: October 18, 2008, 09:48:35 am »
doing want to climb on tdi4 as I can elude all the electronic sensors?
or which mototre tdi is it to pomp rotativa?
what does it initial it has?
talk to you soon :D
Reply #2October 18, 2008, 09:52:56 pm
it modifies mk1
« Reply #2 on: October 18, 2008, 09:52:56 pm »
you'll need to install the mk4 mounts for one.
Reply #3October 18, 2008, 11:49:46 pm
sabatino
it modifies mk1
« Reply #3 on: October 18, 2008, 11:49:46 pm »
Quote from: "jtanguay"
any material I will have' of need the main point is to have your jewel help in to understand what and as to use him/it.
to completed job I will post you' the result.
bye bye :D
Reply #4October 23, 2008, 09:27:03 pm
sabatino
it modifies mk1
« Reply #4 on: October 23, 2008, 09:27:03 pm »
boys but where are you? :(
Reply #5October 26, 2008, 05:22:55 am
dillenger1
  • 777
it modifies mk1
« Reply #5 on: October 26, 2008, 05:22:55 am »
If you dont want to run the computer and all that,you need to research M-TDI   the "M"is for mechanical.Im not sure,but if your to use the 02a tranny you will need the pedal and hydo clutch assembly.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #6October 28, 2008, 11:29:01 am
sabatino
it modifies mk1
« Reply #6 on: October 28, 2008, 11:29:01 am »
Quote from: "dillenger1"
 :D
 :oops:
I ask you scusa,ma in this passage I/you/they have not succeeded in translating the meaning of the kind messaggio,sii to explain better me.
Thanks in advance regards from Sabatino
Reply #7November 08, 2008, 10:54:30 pm
sabatino
it modifies mk1
« Reply #7 on: November 08, 2008, 10:54:30 pm »
:D    good morning to everybody,
I wait with anxiety your suggestions for assemblage motor tdi on mk1.
I have found the motor but also with pomp rotativa the accelleratore is
electronic.
the pompista has told me to climb on pomp and injectors of the 1.9 td 55kw on this
tdi, but are the performances the same?   :(
sure of one answer of yours a regard from Italy from Sabatino
Reply #8November 10, 2008, 04:32:52 pm
it modifies mk1
« Reply #8 on: November 10, 2008, 04:32:52 pm »
Reply #9November 15, 2008, 05:08:03 am
sabatino
it modifies mk1
« Reply #9 on: November 15, 2008, 05:08:03 am »
Quote from: "burn_your_money"
Start here
http://www.vwdiesel.net/phpBB/viewtopic.php?t=6427
 :D thanks for all the documents they have been very useful to my mechanic and the pompista  :lol:
Reply #10November 15, 2008, 07:10:06 am
sabatino
it modifies mk1
« Reply #10 on: November 15, 2008, 07:10:06 am »
:D
Reply #11November 15, 2008, 07:11:13 am
sabatino
it modifies mk1
« Reply #11 on: November 15, 2008, 07:11:13 am »
this is the motor tdi 90cv that I have bought
http://img204.imageshack.us/my.php?image=1000502jf8.jpg
Reply #12November 15, 2008, 07:30:58 am
sabatino
it modifies mk1
« Reply #12 on: November 15, 2008, 07:30:58 am »
Reply #13November 18, 2008, 11:33:35 pm
blkboostedtruck
  • 1535
it modifies mk1
« Reply #13 on: November 18, 2008, 11:33:35 pm »
nice motor ! looks like you got some work to do?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #14November 21, 2008, 04:05:54 am
sabatino
it modifies mk1
« Reply #14 on: November 21, 2008, 04:05:54 am »
hi Duane,il aesthetically motor is equal to the 1.6 d or 1.9td AAzes
now they remove the whole electronic part detdi and they mechanically climb on all
talk to you soon I will post' photo of the change. hi :lol:
