VWDiesel Blog
Facebook Group
VWD on Twitter
General Information
Smoke Tales
I think I made some rubber smoke!
Topic: I think I made some rubber smoke! (Read 3978 times)
October 14, 2008, 10:29:35 pm
October 14, 2008, 10:29:35 pm »
Yeah, I got my new clutch put so I decided to see if it'd burn rubber. :roll: So I stop in the middle of the road, rev it to about 3k rpm, engage clutch 'till it's draggin', floor the smoke pedal and then dump the clutch. Wow, I never dreamed I'd see the day, the tires lit up (sorta) and squealed like mad haha. They didn't stop squealing untill I ran out of rpms in 1st and I didn't bother tryin' 2nd. Anyways both tires made black lines and when I paced 'em I got 45ft for the passenger side and 48ft for the drivers side. :shock: I never thought it could do that! haha. It must have a heavy flywheel I guess lol.
PS. There was more smoke coming out the tailpipe than off the tires. :lol:
October 15, 2008, 12:46:14 pm
spencebm
October 15, 2008, 12:46:14 pm »
ha, hope you don't need another clutch
Ben Spencer
October 15, 2008, 08:56:07 pm
October 15, 2008, 08:56:07 pm »
impressive.
October 16, 2008, 01:10:39 am
blkboostedtruck
October 16, 2008, 01:10:39 am »
don't ya just love the torque of a diesel!
Duane
injector rebuilds call 414-840-1395 for faster service not on line much!
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
3 jettas '82' '04 '14TDI
October 16, 2008, 04:15:32 pm
October 16, 2008, 04:15:32 pm »
Duane
yeah now I gotta figure out how to make it burn in 2nd gear.
March 04, 2009, 02:03:16 pm
March 04, 2009, 02:03:16 pm »
got a turbo on that thing? my rabbit burns all of second gear.. its got about 20 psi and crappy fueling.
March 04, 2009, 03:30:20 pm
March 04, 2009, 03:30:20 pm »
Not yet, I have a VNT-15 but don't have everything for installing it. My plan was to run a 2.25 inch exhaust front to back but I might just make a 2.5 inch down pipe for now and neck it down to the stock system 'till I can make the whole thing. I don't have the oil feed pipe or return either. I do have an LDA so that'll make things fun, except then I'll have to find some turbo injector lines.
March 04, 2009, 09:48:05 pm
March 04, 2009, 09:48:05 pm »
i took half of a TD line and half of the TDI line and slipped them into a piece of steel line just a bit bigger than the 2 lines and welded them together. i cut up my stock T3 oil drain and modified it also to work on the VNT17.
June 09, 2009, 12:16:06 am
Re: I think I made some rubber smoke!
June 09, 2009, 12:16:06 am »
Before i ruined my clutch by doing this ...
I could do what you did in first then quickly slam it into 2nd and keep it going until i hit about 35km/hr (Actual speed, the speedo says like 50-60) when the tires grabbed and threw me forward to about 65 at which point the rpm im GUESSING is pretty high for 2nd.
Blue 2009 CR140 Jetta CBEA/CJAA. Malone stage 2. EGR/DPF/Exhaust-valve deletes. 2.5" open exhaust. ADP Turbo swap. 1-stage nitrous kit.
THROWN ROD
General Information
Smoke Tales
