Author Topic: SOLD ! thanks .don't miss out on this 1.7 NOW WITH PICS  (Read 8882 times)
October 13, 2008, 09:03:40 am
  • 1739
« on: October 13, 2008, 09:03:40 am »
I've got to make room. I already lised my 1.7 KY that i just took out of my transporter. Guaranteed good compression and has piston oilers! this is the heavy duty version of a 1.6 l made for the german government . Same stroke but pistons from a 1.9l . Selling without IP or injectors. Perfect canidate for turbocharging. Very strong runner, just not enough for a 4000 lbs truck.
$1000 CND  or reasonable OBO+shipping/handling
if you close you'll see the pistons squiters[/img]
Reply #1October 15, 2008, 05:37:39 am
saurkraut
  • 904
« Reply #1 on: October 15, 2008, 05:37:39 am »
Just for gits and shiggles, what would shipping be to zip 54016?
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #2October 15, 2008, 08:01:04 am
  • 1739
« Reply #2 on: October 15, 2008, 08:01:04 am »
I think it may not too much. My partner has a relative in the trucking business. We'll find out later -maybe 300-400 ...Certainly not gonna send it UPS
Reply #3October 15, 2008, 10:49:42 am
blkboostedtruck
  • 1535
« Reply #3 on: October 15, 2008, 10:49:42 am »
is there any way you can post pics.? i always wanted to see one! does it look like a normal 1.6 motor?
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #4October 18, 2008, 06:21:04 am
  • 1739
« Reply #4 on: October 18, 2008, 06:21:04 am »
I can take some pics as i have to bring my camera in for another project i have to document. I will even pull the pan to show the piston squiters.
I was thinking that if someone wanted just the short block as that's the real difference between it and a 1.6.
Reply #5October 18, 2008, 06:22:41 am
  • 1739
« Reply #5 on: October 18, 2008, 06:22:41 am »
Oh and saurkraut i never heard back for the brokerage amount but i can get it shipped  for 300-450 plus brokerage.
Reply #6October 18, 2008, 07:54:58 am
blkboostedtruck
  • 1535
« Reply #6 on: October 18, 2008, 07:54:58 am »
Quote from: "the caveman"
that would be great love to see that thing inside and out!
Duane
'66 variant 1500S
Reply #7October 22, 2008, 10:19:15 pm
  • 2932
« Reply #7 on: October 22, 2008, 10:19:15 pm »
I wonder if the heads prechambers the same size?
 It seems like the bigger pistons would shove more air into that little space.
Reply #8October 23, 2008, 04:07:09 am
  • 1739
« Reply #8 on: October 23, 2008, 04:07:09 am »
I'm  also curious  to see what the chambers look like, but i'm not going to open it unless someone takes just the short block etc. As far as i know the head is the same as a 1.6 na. I hope to make time tomorrow to take off the pan and take pics of the piston oilers.
Reply #9October 23, 2008, 11:10:52 am
  • 1739
« Reply #9 on: October 23, 2008, 11:10:52 am »
Vag cat list the same head for 1.7 KY and 1.6 JX but not same as 1.6 na.
Reply #10October 23, 2008, 08:52:03 pm
SR Heer
  • 199
« Reply #10 on: October 23, 2008, 08:52:03 pm »
Marc,
Do you know if it is possible to bore the 1.6TD cylinders out to accommodate 1.9TD pistons or would that leave cylinder walls too thin? What are you planing on putting in your 4,000 lb truck - TDI?
Reply #11October 24, 2008, 04:16:56 am
  • 1739
« Reply #11 on: October 24, 2008, 04:16:56 am »
I'm not sure about boring out a 1.6 although that cetainly seems what my 1.7 is. Others on this site would know more about it.
I now have a 1.9 na what used to be an industrial engine .low milage, never turned more than 3000 rpms , never outsite in the elements, and the price was right.
Reply #12October 24, 2008, 03:41:39 pm
TD_Bunny
« Reply #12 on: October 24, 2008, 03:41:39 pm »
if only the head is the same, would the mounting points be different than the 1.6l? how difficult would this be to drop in from a 1.6l engine bay? ALso, not that i doubt you, but what exactly does "good compression gauranteed" mean  :D  If it was not so far i would consider it but i am sure shipping to AZ would be a monster bill.
Reply #13October 24, 2008, 03:54:06 pm
blkboostedtruck
  • 1535
« Reply #13 on: October 24, 2008, 03:54:06 pm »
see thats why cavy should post pics so we have documentation of a 1.7  even if he took pics. next to a 1.6 block for comparison would be great!
because iv's never seen one!
Duane
'66 variant 1500S
Reply #14October 24, 2008, 04:28:16 pm
  • 1739
« Reply #14 on: October 24, 2008, 04:28:16 pm »
Other than the 1.7 D stamp on the back ,it looks like a 1.6. The 1.9 i replaced it with bolted up perfectly. And since the head is the same, the block lenght has to be also. Pics coming up in a few minutes!
