Author Topic: 1.6D Cam - Same As TD?  (Read 3505 times)
October 09, 2008, 12:26:44 pm
Gernster
  • 87
« on: October 09, 2008, 12:26:44 pm »
seen a 1.6D cam for sale, are then the same lift/duration as the TD/ GTD cams?
Reply #1October 09, 2008, 04:21:39 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #1 on: October 09, 2008, 04:21:39 pm »
I doubt there will be any difference on the valve overlap! :twisted:
Reply #2October 10, 2008, 02:41:53 pm
Gernster
  • 87
« Reply #2 on: October 10, 2008, 02:41:53 pm »
overlap?
Reply #3October 10, 2008, 11:07:59 pm
Quantum TD
  • 1195
« Reply #3 on: October 10, 2008, 11:07:59 pm »
The cams are exactly the same between block type (Hydro or mechanical).
So, any mechanical 1.6 cam is the same TD or NA
And, any hydro 1.6 cam is the same TD or NA
But you can't/shouldn't swap between hydro and mechanical
This data is basd on VWs EKTA parts catalog and part numbers. Some peope claim the mechanical and hydros are interchangeable. I've never tried it, and really don't want to push the envelope on that matter.
Reply #4October 11, 2008, 01:12:26 am
Gernster
  • 87
« Reply #4 on: October 11, 2008, 01:12:26 am »
Thanks mate, thats a great help  :D
Reply #5October 11, 2008, 11:59:24 am
Gernster
  • 87
« Reply #5 on: October 11, 2008, 11:59:24 am »
bugger, its was mechanial  :?
Reply #6October 11, 2008, 08:40:08 pm
« Reply #6 on: October 11, 2008, 08:40:08 pm »
VW never specified using different material in the production of the turbocharged engine.
lets get some pics here to compare!  if you want you could test fit the mechanical into the hydro, and tighten it down and see if its really stiff.
Reply #7October 12, 2008, 03:48:46 pm
« Reply #7 on: October 12, 2008, 03:48:46 pm »
i know some body on here is running a mechanical cam in a hydro head.  they are interchangable... i wish i would have known this before i bough a 1.6td hydro cam, caus ei have a couple na solid lifter cams laying around.
Reply #8October 13, 2008, 09:25:09 am
vwnut84
  • 87
    MK1 - MK4 - W126
« Reply #8 on: October 13, 2008, 09:25:09 am »
Glad someone knows the answer to this question, that's good info to know. Thanks :)
-Chris-
