Author Topic: FS: Alternator Idler Pulley Bearings  (Read 3827 times)
October 06, 2008, 10:31:37 pm
« on: October 06, 2008, 10:31:37 pm »
I've got an '80s 1.6TD with AC, it has the alternator driven off the AC compressor via a short belt with an idler pulley.  The bearing in mine was toast causing it to rattle and chew up belts.  Cost for a new pulley - $65!  Seems a bit much...
Well, I found the bearings and grabbed a stash of them.  I've replaced mine already using a bench vise and a socket as a press, took maybe 20 minutes and the problem is gone!
The bearings are a sealed ball bearing good for up to 15,000 RPM.  They're the same type as the factory ones, meant for the same application.
I've got a bunch of extra bearings - $10 including shipping to anywhere in Canada or the US, or 2 for $15.  PM if you're interested...
Reply #1October 07, 2008, 12:51:11 pm
Turbinepowered
  • 1206
« Reply #1 on: October 07, 2008, 12:51:11 pm »
Guessing these are the front bearings only, or are fronts/rears interchangeable.
I'm in for one, possibly two if they interchange. I have a noisy alternator!
Reply #2October 07, 2008, 02:13:24 pm
« Reply #2 on: October 07, 2008, 02:13:24 pm »
He is talking about the idler pulley bearing.
