Author Topic: 87-94 ford diesel glow plug controller for a 1.6TD???  (Read 13728 times)
Reply #15October 05, 2008, 08:38:16 pm
53 willys
« Reply #15 on: October 05, 2008, 08:38:16 pm »
Quote from: "zukgod1"
Mark I have a spare GP relay you can look at for this project.
Personally I think using a stock relay running a ford starter relay is the best way to go.
thanks Dan! I may just take you up on that...I think I can get this beast fired up this week..so I will need a GPR....
Reply #16October 05, 2008, 08:51:15 pm
blackdogvan
  • 574
« Reply #16 on: October 05, 2008, 08:51:15 pm »
Isn't it the case that the dedicated LED circuitry lies, and you are better off monitoring straight off the bus bar/s
Ya know when it went in I didn't trust the LED bit & went to the bus bar! Good memory!!
As for the gasser relay base I wouldn't be surprised if it was the same.
1991 Vanagon 1.9 mTDI
Reply #17October 06, 2008, 10:08:14 am
« Reply #17 on: October 06, 2008, 10:08:14 am »
Maybe that car you found @ the PnP had a relay?
Those things are spendy!!!
Reply #18October 06, 2008, 10:10:11 am
53 willys
« Reply #18 on: October 06, 2008, 10:10:11 am »
no it's not there :(  I checked..all the relays had been pulled..the ones left on the seat did not seem to be the same style as the ones I have seen....
Reply #19October 06, 2008, 11:03:29 am
« Reply #19 on: October 06, 2008, 11:03:29 am »
figures :(
Reply #20October 06, 2008, 06:02:02 pm
mk2diesel
  • 60
« Reply #20 on: October 06, 2008, 06:02:02 pm »
Ford glow plugs are 10.5 V units    that big twisted bit of metal is a dropping resistor ( restricts the amount of MAX amperage to the plugs )
the 2 systems are not compatible ...  its quite easy to hook up a VW glow plug relay without the temp sensor ( gives max heat time without it)  the glow plug indicator  bulb must be hooked between the B+ and the relay to indicate correctly ( not to ground )  each tiome you hit the starter, the relay drops out and then back in for 10 seconds after the key is relaesed.
Reply #21October 07, 2008, 12:48:38 pm
arb
Re: 87-94 ford diesel glow plug controller for a 1.6TD???
« Reply #21 on: October 07, 2008, 12:48:38 pm »
Quote from: "53 willys"
I'm gonna keep that relay cause I am keeping my in-tank transfer pump as a diesel lift pump..so I dont want to try and wire it into the VW fuse box.
87 - 94 Ford's are likely to be fuel injected... This means your in tank pump is likely to be a high pressure pump. This will be a real problem for your IP as far as timing is concerned, maybe seals as well - or so it is said. You might want to check the pressure - I don't think the IP will tollerate much more than 3 - 4 PSI. Every in-tank pump I've seen is at least 20x that amount.
On my conversion I removed the in tank pump and by-passed it keeping the fuel gauge sending unit:
http://www.vwdiesel.net/phpBB/viewtopic.php?t=15633&postdays=0&postorder=asc&start=45
Reply #22October 07, 2008, 01:51:05 pm
« Reply #22 on: October 07, 2008, 01:51:05 pm »
Quote from: "arb"
The in tank pump isn't high pressure.
He's referring to his GLI here not the Ford. The relay he is refering to is the OE fuel pmp relay in the GLI.
The high pressure pump is where our water separators would be and he has removed that.
Also the IP will not only handle more than 3-4psi but it will like it as well.
Giles has even commented on this somewhere on this board.
I'm running 12 psi currently, give me a really good dynamic advance.
Reply #23October 08, 2008, 06:56:59 am
arb
« Reply #23 on: October 08, 2008, 06:56:59 am »
WOW ! My understanding was contrary. OK, I'll have to test this when I start driving my conversion soon. My electronic lift pump is switched and I only installed it to quickly bleed air from the lines when new or if I ran out of fuel due to fuel gauge malfunction - something that's happened to me.
Reply #24October 08, 2008, 07:10:16 am
53 willys
« Reply #24 on: October 08, 2008, 07:10:16 am »
Vw's intank pump (transfer pump) is 6-7 psi...that is what mine tested at anyway.
I may end up ditching the oem pump after all and running a "raptor lift pump" I pulled the ECM out of the car last night and i'm pretty sure the ECM is what controls the transfer pump......
Reply #25October 08, 2008, 07:10:39 am
Mark(The Miser)UK
  • 1557
« Reply #25 on: October 08, 2008, 07:10:39 am »
Quote from: "blackdogvan"
Yep it's the same base. There is about 3 wires to move/reuse. I have a list somewhere
Mark-The-Miser-UK
Reply #26October 08, 2008, 07:13:03 am
53 willys
« Reply #26 on: October 08, 2008, 07:13:03 am »
Quote from: "Mark(The Miser)UK"
man that would be some good info to post up if you got it??
it looks like it's missing the glow plug light spade/connection at my quick glance I took...
Reply #27October 08, 2008, 07:40:59 am
arb
« Reply #27 on: October 08, 2008, 07:40:59 am »
Can you point me to these posts by Giles where he says a high pressure lift pump is a good thing ? I found just the opposite when I searched...
http://vwdiesel.net/phpBB/viewtopic.php?t=12976&highlight=lift+pump+high+pressure+timing+giles
Reply #28October 08, 2008, 07:44:15 am
« Reply #28 on: October 08, 2008, 07:44:15 am »
Quote from: "arb"
You need to read the thread you linked again, Giles dosnt say running a lift pump is bad he's saying it's not needed if your vane pump is good.
I'm not searching for a thread I read once sorry. I dont have time and if you dont belive me pick up the phone and call Giles.
Reply #29October 08, 2008, 08:33:44 am
arb
« Reply #29 on: October 08, 2008, 08:33:44 am »
Quote from: "arb"
No worries - I just thought maybe you had it book marked :-)
Like I said, I'll have to do some numberic testing w/ and w/o my pump.
