It's kind of hard to tell in this picture, but when pulling and re-ringing pistons I discovered that the oil ring in #4 wasn't expanding at all: it was being held shut by all the carbon and other crap lining the piston..
Apparently all of those extra pieces you get in the super-low budget pump timing kit are good for something
First coat of outer primer
Tons of dents (pre-popping)
This area has been tons of sanding/filler work to flatten even with most of the pitting pulled and hammered out.
The body is almost completely smooth and ready for basecoat at this point...
My 1.5 is now ready to go. Just need to finish the body and drop the engine in.
