Author Topic: newly rebuilt starting time?  (Read 2298 times)
October 02, 2008, 01:57:14 pm
dillenger1
  • 777
« on: October 02, 2008, 01:57:14 pm »
how much will new rings/bore affect the compression?I was under the impression that i wouldnt need the glow plugs to start it.It isnt broken in yet.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #1October 02, 2008, 02:04:54 pm
arb
« Reply #1 on: October 02, 2008, 02:04:54 pm »
What tempurature is the engine / air when you are trying to start sans G.P. ?
Reply #2October 02, 2008, 02:12:41 pm
« Reply #2 on: October 02, 2008, 02:12:41 pm »
it'll take a little bit for the rings to seat, and before then the compression will be a bit lower...  totalseal sells some quickseat dry lube stuff that seems to do the trick fairly quickly...
Reply #3October 02, 2008, 02:27:11 pm
« Reply #3 on: October 02, 2008, 02:27:11 pm »
Ya rings take close to 5k to be fully seated.
First 500 miles are really important..
Reply #4October 02, 2008, 02:40:45 pm
dillenger1
  • 777
« Reply #4 on: October 02, 2008, 02:40:45 pm »
Its about 60-65degrees F.So do you guys think theyre needed(glow plugs)
Reply #5October 02, 2008, 03:12:23 pm
« Reply #5 on: October 02, 2008, 03:12:23 pm »
I would, just to make it easier to start...
